Oil Filter question for Patman (new filter possibly better than K&N?)
Hey Patman if you read this or anybody else who is knowledgable on this I have a question regarding a couple oil filters. We all know that the K&N flows really well and has decent but not the best filtration. We also know that for high performance engines such as the ls1 that a better flowing filter is better than a high filtering low flowing filter.
I found this link for this filter which filters less than the k&n but flows nearly twice as much looking at the specs
http://www.oilfilterstudy.com/donaldson.htm
vs the K &N
http://www.oilfilterstudy.com/KN-3002.htm
the donaldson flows way more than the K&N I wonder if this filter will actually be better for our needs than the K&N and at a cheaper price?
vs the K &N
After looking more at that page...I see the AMSOIL looks like it filters a little better than the K&N, but flows almost as well... I wonder if that would be worth the little bit of flow difference to have the bit better filtration? http://www.oilfilterstudy.com/amsoil-sdf24.htm
Intersting links...
Intersting links...
BMW ///M Nerd
Originally Posted by Tudds
Frams are cardboard filters!!!! BLAHHH You can dent them by flicking them!!!
I dunno about that one in the can though... X2 whatever
Originally Posted by Damian
LOL.....You guys crack me up, it's a OIL FILTER PEOPLE!
Use good oil, and change it every 3000 miles. The oil filter aint gonna matter much unless you're running 10K old oil
LSX Mechanic
Originally Posted by silverbeast
a guy i worked with was running a fram filter on his daughters car.the cotton like filter came apart and stopped up the screen in the oil pan. it blew the motor up. all over a pos oil filter! so thats why i dont use fram anymore. i stick w/ ac delco.
FWIW I have ran a plain jane AC Delco filter on every F-body i've ever owned with one problem...
Originally Posted by Mike K.
Also Patman why do you use the bigger K&N filter instead of the stock sized one?
Originally Posted by Patman
Bigger is always better, as you can see on that filter study as to how much more the larger filter flowed over the stock sized one. It just so happens that my LT1 takes the exact same filter that they were testing in that study.
The more I look at it, the Amsoil and Mobil 1 are excellent filters.
It is indeed possible that this filter could be a better choice, it's just a matter of how readily available it is. The K&N is probably easier to find, plus we know it's built very solidly as well. I also like the Fleetguard, it looks like a very good filter too. I may be looking for an alternative to the K&N in the future, because when I get a C5 I won't be able to buy the K&Ns from my usual source, as they don't stock the HP1007 there. The Fleetguard is easy for me to get though, since there is a Cummins dealer ten minutes from me (and they are open 12 hours a day, even on Sat and Sunday)
Originally Posted by Tranzor_Z28
The Wal-Mart Supertech is actually a very good filter considering the price... if you don't like the $10 K&N, check that one out. Can't beat $1.97 at Wally World.
Originally Posted by mrb00formula
For the LS1, which attributes would be more important- better flow or better filtration?
