What springs for the G5X3 cam???
Old 06-10-2004, 01:52 PM
Ravenous T\A's Avatar
Question What springs for the G5X3 cam???
I have looked at a couple of sites on valve springs, but I don't know if machining is gonna be required for my stock heads to get them to work? I have a 98 TA with the TR224 cam, I am buying a used G5X3 cam and need to know which ones to use, I saw that REV #VS1116, Crane #144832, and Manley #221426 make springs that can handle upto a .625 lift, but will I need to machine the seats to get them to work? I am looking at these for Budget reasons.
Old 06-10-2004, 01:56 PM
TVWilkes's Avatar
We have the whole spring kit."GOLD" springs,titanium retainers,seals,and seatbases for $295.00.The springs will run up to .650 valve lift.
Old 06-10-2004, 02:02 PM
LS1Maniac's Avatar
How many miles will those springs last before needing replacement on a G5X2 or 3?
Most of the people I know who went with the G5X series of cams went with dual springs such as crane and comp offer.
Old 06-10-2004, 02:20 PM
PREDATOR-Z's Avatar
15000 miles or so. Just check them at least once a year.
GOLD spring are top notch IMO. Why pay 500+ for comp when u can have those.
921's work BTW.
Old 06-10-2004, 02:29 PM
I have Titanium retainers (from my TR224 Kit), do I just need the springs? and will I have to machine the heads for bigger seats?
Old 06-10-2004, 02:46 PM
AZ Power & Sound's Avatar
the retainers usually dont work for other springs... need new ones!
I would use the Comp 921s... thats ALL I use on my customers cars... I had a guy switch from the Cranes to 921s as well, so seems like people like them
Old 06-10-2004, 03:01 PM
What about 918"S, they take upto a .625 lift with no-machining?
Old 06-10-2004, 03:43 PM
Orange Peel's Avatar
918's will crumble under that cam, don't use them, only good to .600 lift by the way. I went with the 921 which Lou uses with the cam, and they work great. They have enough seat pressure for the cam and everything. It's up to you though, I didn't want to go with the Comps initially for the cost involved, I wanted the Crane's dual spring, but they were national back ordered, so I bit the bullet and got the 921's, no regrets, they are a great spring.
I don't know about any machining neccessary with the 921's anyways. Not sure if the '98's have problems, but my '99 fits perfectly.
Old 06-10-2004, 03:58 PM
What about the other springs I listed, the REV and the Manley's, will they work and do they require machining, I am starting to lean towards the "GOLD" ones from Patriot Performance cause of cost.
Old 06-10-2004, 04:00 PM
TVWilkes's Avatar
IMO, the "GOLD" springs are the best spring,regardless of price and the manufacturer.
Old 06-10-2004, 04:04 PM
Rev's I say NO, just not that great from the reports of breaking, etc. Don't take the chance, I talked to Thunder about them, they don't like them either, they prefer the Comp and Cranes. Never heard about the Manley's, I stay stick with either Patriot (Never used them), Crane or Comp.
Old 06-10-2004, 04:14 PM
Do I have to do anything special to get the "GOLD" ones in, like machining ( can U tell this is my biggest concern ) and will the retainers from my TR224 cam work (to help drive cost down, I told u this was a budget deal )
Old 06-10-2004, 04:16 PM
The retainers won't work from a single spring. The retainers are larger for the dual springs, just get new ones for the correct spring and sell the old ones, people snag them up FAST! Don't cut corners brother, you will pay out your *** in the long run and wish you just bought the right stuff.
The 918 retainers were MUCH different than the 921 retainers, just so you know.
Old 06-10-2004, 04:20 PM
Cool, thanx for the retainer info
Old 06-10-2004, 04:33 PM
No sweat, just trying to save you some heart ache Or poket book ache
Old 06-10-2004, 05:22 PM
Louis's Avatar
Cranes do not have enough pressure to hold the cam. Im not sure on the exact specs of Terrys Gold series, but the 921s or Isky 295Ds work with the cam with no cutting of the head. Drop right in.
Louis
Old 06-10-2004, 05:34 PM
TVWilkes's Avatar
Louis
The " GOLD " spring have 135-140lbs of seat pressure.They will hold the cams.It will not require machining of the head,they are a drop in style.
Old 06-10-2004, 06:02 PM
Unaffliated Racing's Avatar
you can use a 918 spring on that cam with no problem, comp runs them on cams that have XER lobes and .615" lift all day long...but I love the way Terry has an unbiased opinion.....
Old 06-10-2004, 06:28 PM
I just think the 918's wouldn't hold up very long to the X3 abuse, plus the single spring, err, no comfortable with the aggressiveness of the X3, dual spring all the way. Which ever brand floats your boat
Old 06-10-2004, 07:15 PM
Kenny D's Avatar
COMP CAM 921 valve package.
Quick Reply: What springs for the G5X3 cam???
