AI 226cc vs. TSP PRC 2.5
Ask Phil what he recommends for his heads in your car.
Then take that recommendation AND your head flow data, and call Martin Smallwood, and see how/if he would change the cam.
Either way, have Martin Smallwood's opinion on the final cam specs, and absolutely have Martin grind it on the hand polished cam motion core with cam motion lobes with the cam doctor report.
LS1Tech Premium Sponsor
Here are a few quick links to people running our 2.5 LS6 heads as well. Most opt to run either 2.5 5.3l heads or the PRC AsCast heads now vs the LS6 which is why there isn't many recent dyno or track results posted on tech. I will say thousands of customers run our 2.5 LS6 heads. Those heads flat out perform. Since GM stopped making the heads at a reasonable cost we only port customer supplied castings. Given the inflated costs of them used is why most opt for different routes now.
If you would like any more info give us a call at (512) 863-0900. We would be happy to go over your combination and recommend the best heads and cam set up. We would also be more than happy to do a custom camshaft if needed for your combination on our new TSP lobes ground on Callies cam cores. Lastly, we too have the option to do a cam doctor report for you as well that will be printed out, not hand written. Just give us a call.
Lonnie
https://ls1tech.com/forums/dynamomet...-cube-ls2.html
https://ls1tech.com/forums/dynamomet...very-well.html
https://ls1tech.com/forums/dynamomet...-454-rwhp.html
Lonnie
__________________
NOW OFFERING TSP BY YANK CONVERTERS
COMP - FAST - PACESETTER - WISECO PISTONS - LUNATI - CALLIES - NEW TSP BRAND CRANK & RODS - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - ARH HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - PRECISION INDUSTRIES - YANK - CIRCLE D - AND MORE!
NEW NUMBER (512)863-0900
At the end of the day, you need to go with what makes you feel confident. Research your options and make the necessary phone calls. Talking to these people will go a long ways in helping you choose who to go with. If you like the service or knowledge provided by tsp over tea, or advanced induction over whoever, you should probably use the one who answers your questions the best. If their service sucks, you probably don't want to do business with them anyways. Because, ultimately, all these options are going to yield very similar results.
