TSP 228R reverse split questions
Old 06-11-2004, 08:58 AM
M6HTZ's Avatar
Default TSP 228R reverse split questions
I've searched and still have a few questions. I am planning on running this cam with stock heads, ASP pulley and Longtubes. The Specs are 228/224 reverse split .588/.581 on a 112 lsa. I have tuning so that shouldn't be a problem.
Are stock 3.42 gears in a M6 car going to cause problems, I plan to upgrade to a 9" in the future?
What rpm will I have to shift at?
Anyone with track times or dyno information?
Thanks
Old 06-11-2004, 10:23 AM
JRcamaroZ28's Avatar
I have a 227/224-112 +4 .569/.563 and made 380/371 after tuning. Peaks around 6250+/- and pulls had all the way to 6500. your cam is a bit bigger than mine so it will pull a little higher than mine but not much more. all my mods are in my sig below
JR
Old 06-11-2004, 11:59 AM
M6HTZ's Avatar
JR
Thanks for the info. Sounds like a nice setup.
