AFR heads have the Patriot GOLD springs??
I was told by a VERY reliable source that the new AFR heads that are rated for the "high lift" cams come with Patriot GOLD dual springs. Has anyone seen a set of the AFR heads outfitted for higer lift cams? I know Tony from AFR is on this forum alot, maybe he can verify this. Tony, are you guys buying springs from Patriot? I'm interested in this because maybe you'll help me confirm my opinon that it's the best spring availble on the market today
LS1TECH & Trucks Sponsor
Patriot's Gold springs are the best springs on the market IMHO. I don't think it will be long before they're used in just about every set of aftermarket cylinder heads!
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
you guys make it seem like patriot makes the springs. Yeah Im sure they are excellent springs, but they are prob. made in mexico for 15 cents a dozen. It is good to see sponsors working together.
Why are they the best in your opinion?
hmm... that sure is strange cause the guy that told me about AFR buying the springs from Patriot is right here in Alabama and makes ALL of the Ti retainers for Patriot's spring kits, which are also made here in the USA. The guy also only makes the super 7 Ti retainers for Patriot exclusively to use with their proprietary spring design. I may be wrong.. but I'm pretty sure that the machine shop owner I talked to today wouldn't lie to me. I guess if Tony or Terry posts up, I'll be able to tell you that you're full of **** on the mexico deal, but it wouldn't be the first time you've posted false info. Time will tell......... So, maybe someone that isn't so closely associated with one of Patriot's main competitors (that has spread untrue rumors about them in the past) will step up with some TRUE and FACTUAL info on this subject... not just second hand hearsay that some are so proficient at.
Gomer get your red white and blue patriot panties outa your ***. I was only stating that patriot does not make the springs and has someone else make them. I said they were probably made in mexico like everything else is nowadays. I also did state they are good springs. AFR is top notch and wouldnt use junk. I will be purchasing a set of the 225's when they come out. (with additional work by AS) As for me staying false info. I call it as I see it and as how people post it. Your the one whos so full of ****. Hey as for me being so closely associated with patriots competitor, yeah I Knew Jay for over 10 years. How long have you known Terry? You guys must be dating or something the way you kiss his *** so much. Why dont you tell everyone on here how you are affliated with patriot and get it over with.
Hey Mike, who pissed in your coffee today (telling someone to pull the red, white and blue panties out of their ***, wtf)? You have a real attitude. Who cares where they're made if they are a well designed and manufactured part anyway.
Originally Posted by 99Fbody99
Hrm..only one company uses the "gold" finish..and has for years..
And does a lot of private labeling...
Isky....
That is all...
Isky....
That is all...
GUYs, what matters here is Patriot "Gold" springs are one of the best.
This argument over where the parts are made is BS. Do I need to remind you that Camaros were built in Canada?
IMO, if AFR was to use the Pats. that would be great!
To my knowledge, there hasn't been a Patriot Gold spring failure yet. Even with the HUGE cams that everyone is using nowdays. I'm glad they are on my heads, I'm sure they can handle my baby cam and once I step it up I still will have no worries.
I am running the GOLD springs on my TSP race heads with a 238/242 cam. It's been the to track quite a few times and is driven on the street also. No problems at all. They must work pretty well.
I don't see why this deal about the fact that someone else is making the springs matters, there is no reason that should have any been brought up. Hardly any company out there makes all the stuff they sell and put their names on at their own shop/buisness.
Springs!!!
Hello...
I was considering not responding just to keep the "entertainment value" of this thread going....
BUT....just to put all minds at rest, YES...AFR is currently installing Patriot "gold" dual springs as our "standard" valvespring. We are having springs custom made specifically for us, of very similar premium wire material, but the lead time for a run of custom springs is insane. We felt that of all the dual springs currently available, the Patriot spring (not manufactured by Patriot of course) was arguably one of the best springs we could have installed till our own production run is complete.
Our "upgrade" spring is similar in material, but has additional seat pressure (145 lbs.) and a higher spring rate (400 lbs. @ .600). We recommend our "upgrade" springs with their higher pressures in applications where gross valve lift is .600 or more and/or the RPM level you expect to turn is approaching the 7000 mark. We also recommend installing the COMP "R" lifters with our upgrade spring as it has a different oil metering system which better handles the additional spring load.
Terry....Thanks for all the help with the valvesprings!
Regards to all,
Tony M.
Regards to all,
Tony M.
