Straub Bushing Trunion Kits?
Some use a copper alloy insert pressed into a tool steel body on the push rod end in a v or radius "cup" configuration. Most will also employ a tool steel (H13) ball adjuster on the rocker end.
Trend uses a bronze insert where as Manton uses a copper alloy. Trend has also introduced a self lubricating tool steel "V40" push rod that also employs a cup on the push rod and utilizes a ball adjuster on the rocker arm.
As machinistone mentioned, this helps decrease wear from better coefficient of friction and better lubricity in high rpm engines utilizing very high spring pressures or where push rod angles are at extremes.
As for the member who doesn't believe machinistones findings with other trunion kits and stock trunions. Kurt Urban himself said that in his road race/street/autocross applications he builds engines for, that he has seen the trunions wear just like machinistone has in as little as 5000 miles.
I'd be willing to bet if more people pulled their rocker apart, they might find something similar to the picture machinistone posted.
Crane used this technology on their shaft system years ago. FE Fords and Chrysler used it in OEM applications. The bushing material is a high grade alloy with lubricity properties.
We are all modifying this stuff beyond OEM limits. The MAJOR advantage of bushing over the needles is if the bushing does fail it will wear and get loose and you will hear the rocker noise. If the needle fails you will hear and feel the needle lock up the oil pump.
Also, if put the needles on a flat surface and lay a flat surface on top on them the needle that takes all the load is the largest needle. With the bushing, 1/3 of the radius takes the load.
Optional fastener kit to be available.
#40
