LS1 main caps directional? Help needed!
Old 06-14-2004, 01:47 PM
ktmrider's Avatar
Question LS1 main caps directional? Help needed!
Getting ready to start engine assembly and noticed the machine shop has 2 of my main caps in "backward" when they line honed my mains. It obviously bolted up fine for them to do this but I am not sure of the consequences.
Any thoughts or concerns? Thanks!
Old 06-14-2004, 02:00 PM
Scalpel's Avatar
Hmmm, well I'm pretty sure you can't switch them now.
I wonder if it'll be fine since they were line honed in their respective positions?
Old 06-14-2004, 04:56 PM
cantdrv65's Avatar
I know in an old SBC, if the bearing grooves were installed facing the wrong direction you would soon spin a bearing!!!
Old 06-14-2004, 11:33 PM
ktmrider's Avatar
I did not mention that the caps are in their respective order, ie 1-5 are where they belong. Just #2 and #4 are backward. You can definitely see where the cap bearing alignment groove is "matched" to the block one. Cantdrv65 may be right, this could cause the bearings to spin. Not like I need to make this easier since spun bearings killed the donor motor in the first place.
Old 06-15-2004, 05:21 PM
Senior Member
Country Boy's Avatar
Go back and have them do it right for free. Dont just "live with it". They are directional for a reason.
Old 06-15-2004, 10:37 PM
triumphman's Avatar
the middle caps can flipped, they are machined with bearing tang grooves on both sides of the cap, as long as the block and cap cleaned at the parting line you should be fine.
Old 06-16-2004, 09:08 AM
10secondZ's Avatar
Only #1 and #5 are dual tang...Take it back for sure!!if the centers are flipped it's no good man..the side bolts wouldnt line up correctly if the center caps where flipped (they might thread..but not seated in the register properly)..make them re-do it. Good luck...BTW...when all the mains go back in..the bearing tangs on the cap must be on the oposite sides of the block tangs for proper alignment and bearing crush.
Carter
Old 06-17-2004, 07:12 PM
cantdrv65's Avatar
Carter
What he said...
Old 06-18-2004, 08:15 AM
ktmrider's Avatar
Thanks for all the input, folks! Update, I had the machinist come over to look at the block. In reality, they DID line hone with the caps in the proper orientation. When they vatted and washed the block they removed the caps. When I picked it up they had just put the caps on without torquing or centering. I freaked prematurely but hey, I'm a man right?!?
Last, I installed the crank yesterday and checked clearances. Nothing over 0.0017" so things are looking good! Hope to light it up by Monday. Say a prayer and keep your fingers crossed for me.
Old 06-18-2004, 09:45 AM
Scalpel's Avatar
Did they label the caps so that you know which ones go to which positions?
Old 06-18-2004, 09:49 AM
ktmrider's Avatar
Yes, they stamped the caps for both position and direction. It also matched the GM stampings. This is how we realized where the confusion came from.
Old 06-18-2004, 11:49 AM
10secondZ's Avatar
That motor will be tight man.Nice oil pressure for sure too Good luck!
Carter
Old 02-14-2011, 04:16 PM
Johnnyfever95's Avatar
I have the same problem I don't know how #2 #3 #4 caps go. Are the barring locks suppose to line up or they the opposite of each other? I know #1 and #5 caps have to go inward so the timing cover and rear main seal cover can be bolted on. But just can't figure out how the middle three go. Can any one help?
Old 02-15-2011, 12:03 AM
01ssreda4's Avatar
Why would you mark main caps? They are in order from the factory and you guessed it, they are numbered and all numbers facing right side up. You literally cannot put them in incorrectly unless you aren't paying attention.
Old 02-15-2011, 01:18 PM
5.3LJimmy's Avatar
1,2,3, & 4 have the side that is stenciled on the drivers side of the block and 5 has the number on the passengers side.
Old 02-15-2011, 01:20 PM
5.3LJimmy's Avatar
You are asking a question from something that happened so long ago that the OP likely does not remember the answer.
Old 02-15-2011, 08:19 PM
S10xGN's Avatar
Actually, a "thread jumper"resurrected this old thread with the same question the original poster asked...
Old 02-15-2011, 09:03 PM
1toDV8's Avatar
One thing that I learned over the years building engines, is that when you have "unmarked" caps rods, or mains, look at the grinding/sanding marks on the inside bearing area! If they dont match 100% then you need to switch them up.
If you had that engine line bored, there will be distinguishing marks on each cap. You have to look close but its there. No boring bar of any type scores the same from one end to another.
Old 02-15-2011, 11:02 PM
01ssreda4's Avatar
Yeah, I seem to forget that these ancient threads keep getting bumped to the top.
Old 10-12-2011, 05:19 AM
thanks
Quick Reply: LS1 main caps directional? Help needed!
