Nitrous 5.3 build
Old 04-13-2016, 08:58 PM
steves86ta's Avatar
Originally Posted by uraloser2me2
It was recommended by LJMS as a good off the shelf nitrous cam for a carb'd 5.3. It seemed like a pretty good choice given the only good discussion I found about the topic was in this yellow bullet thread:http://www.yellowbullet.com/forum/sh...d.php?t=526846
My BTR seems to love the nitrous. But it's also my bad combination.
According to the impeller charts I'm getting close to 300 more hp when I hit the button.
I assume I'm making another 100-150 at the rpm the bottle brings me to. Then the nitrous on top of that
Old 04-15-2016, 09:18 PM
uraloser2me2's Avatar
Installed the timing chain tonight. Have a couple of issues I am not sure what I did wrong. 1st the oil pump gear freely slides on the crank. 2nd the chain is touching the oil pump very slightly. I guess i will take it back apart Sunday and double check that the bottom gear is all the way back on the crank. I was also getting tired and did not look to see it the chain was different on the other side. Not sure what to do about the oil pump gear. I reused and old crank key maybe I just need to use a new one.
Old 04-16-2016, 10:57 AM
KCS
Moderator
KCS's Avatar
Don't worry about the oil pump drive, it doesn't really matter if it slides freely.
As far as the chain, sometimes that happens with OEM pumps and double rollers, even with the pump spacers installed. Just take it off and grind a small area where the chain is touching behind the pickup flange. FWIW, the Melling pumps have a small area already ground to clear.
Old 04-16-2016, 11:46 AM
Thanks for the reply. I realized this morning the balancer would hold the oil pump drive in place. I also ordered a melling pump today after doing some research.
Old 04-16-2016, 05:23 PM
5FOX3's Avatar
the melling pump comes with the spacers even to clear. I was just checking it all out for my sbe set up yesterday. you went the route I was contemplating and then said screw it lol itll do for now
Old 04-16-2016, 05:43 PM
The melling pump did not come with any spacers. I purchased a 10296 meling select pump. It clears better but I still only have .035 clearance. I am going to check to make sure the crank sprocket is pressed far enough back. If it is I will clearance the pump.
Old 04-17-2016, 10:01 AM
steves86ta's Avatar
What timing set is that?
Old 04-17-2016, 01:03 PM
Liberty Performance Components is the brand.
Old 04-20-2016, 03:36 PM
Still waiting on the heads to be finished up. I should have them Friday. Stopped by today and took a few pictures of the progress. Supposed to be milling them tomorrow.
Old 04-20-2016, 03:57 PM
"I MAID THEESE"
Mavn's Avatar
What heads are those? 243.s?
Old 04-20-2016, 04:21 PM
706 5.3 heads
Old 04-20-2016, 04:33 PM
  #32
"I MAID THEESE"
Mavn's Avatar
706 5.3 heads
Ill be using the same heads on my build
Old 04-20-2016, 05:06 PM
  #33
Cool, I know these are not ideal, but I only have 500.00 in them including the btr .660 stpring kit.
Old 04-20-2016, 05:59 PM
  #34
Got bored last night so I wrinkle coated the valve covers.
Old 04-21-2016, 04:16 PM
  #35
z twenty h8's Avatar
Looking good...I turned to painting while waiting for parts too!
Old 04-21-2016, 04:35 PM
  #36
moekluse's Avatar
[QUOTE=steves86ta;19223762]Also, which Rods are you running? I do not see any Eagle 6.098" rods to go with those pistons.
Only finding K1 rods
Im looking for k1 rods 6.098 with a .945 pin. But i can only find eagles lol. Im thinking about compstars for my 1000hp 5.3
Old 04-21-2016, 05:00 PM
  #37
[QUOTE=moekluse;19232697]
The eagles I am using are 6.100 in length with a .945 pin. The part number is 6100m3d. You can also get scat in a 6.100 with .945 pins p/n 6100945 or 6100945a with arp2000 bolts. For a 1000 hp build I would upgrade the rod bolts at least to arp2000 bolts.
Old 04-22-2016, 03:06 PM
  #38
Looks like my heads are going to be ready today. Valve job is done and the heads were milled .042. Just have to check spring height.
Old 04-23-2016, 08:23 PM
  #39
Didn't get a lot done tonight dealing with a sick little one. Drilled the new lifter trays. Should have taken pictures. Also don't try it without a unibit. Lifters are installed. I also got the rear cover on. If every thing goes to plan I will degree the cam, check piston to valve, and get the heads on tomorrow.
Old 04-24-2016, 08:44 AM
  #40
sbdgbody's Avatar
good looking build
Quick Reply: Nitrous 5.3 build
