Nitrous 5.3 build
Old 04-24-2016, 06:03 PM
  #41
uraloser2me2's Avatar
Originally Posted by sbdgbody
good looking build
Thanks! Couldn't check piston to valve today. Missing a few tools I will have to borrow tomorrow. I set the heads on the motor and confirmed that my headers will have to be up and forward unless I high mount the alternator. I also forgot the truck block is missing the upper bolt hole for a low mount. I just have not seen i high mount alternator bracket I really like.
Old 04-28-2016, 12:06 PM
  #42
I still need to check piston to valve, been slacking after a bout with a stomach virus. Last night I test fit the windage tray and oil pan. Had to drill out a couple of holes on the tray to fit the arp studs. I also need to check that the pickup is the correct distance from the bottom of the pan. Will probably do that tonight. Made some shims to center the oil pump on the crank. Looks like the front cover is going to need some clearancing. I test fit the intake and it is also going to need work. Not sure if it does not fit because of the head milling or the holley casting is just bad.
Old 04-29-2016, 10:18 PM
  #43
Finally, got cam degreed with 0 advance on the crank gear everything was where it should be. Checked piston to valve and the valves did not touch the clay on the intake or the exhaust. Got block drilled and tapped for the alternator mount and clearanced the timing cover. The bottom right of the oil pump was just barley touching it. Had the machine shop fix my intake fitment issue today. Just need torque the heads and get a set of push rods.
Old 05-02-2016, 10:03 AM
  #44
Over the weekend I got the oil pump centered on the crank per the melling video on YouTube, and installed the oil pan and front cover. Just need a set of pushods now. Going to try and install the balancer tonight, but my installer is not big enough or long enough for the ati hub so I might need to get creative. Still not happy with the oil pan but gmpp says it is correct.
Old 05-04-2016, 05:47 PM
  #45
Got the pushrods today. Went with a 5/16 7.350 with a .120 wall. Checked preload with these installed and come up with .067 from zero lash to 22ft lbs.
Old 06-22-2016, 12:17 PM
  #46
sbdgbody's Avatar
looking good any up dates
Old 06-22-2016, 12:39 PM
  #47
Motor is in the car working on the tune up. Should have it to the track soon.
Old 07-08-2016, 09:27 PM
  #48
Have been working on the tune. The picture is a second gear pull I let out at 5900 because it was leaner than what I wanted. Timing at WOT is 28 degrees. Going to change the power valve, jet it up a little more, and go 1 heat range hotter on the plugs. Hopefully 1 or 2 more jet changes will get it where it needs to be or I will have to order a bigger jet kit.
2nd gear pull 338 hp and 317 ftlbs
Old 07-11-2016, 09:11 PM
  #49
Finished round 3 with the carburetor tonight. Changed power valve to a 4.5 and went up 2 more jets front and back. Hopefully it will get my "laddle" where it needs to be air fuel wise.
Old 07-14-2016, 09:30 PM
  #50
I think I am pretty close am the tune up. 28 degrees timing and the air fuel is between 12.3 and 12.5 at wot. I am going to try going up 2 more jets and see if I still gain power.
364 whp and 333 torque
Old 07-15-2016, 12:58 PM
  #51
AJatNitrousOutlet's Avatar
Nice looking build!
Old 07-15-2016, 01:10 PM
  #52
Originally Posted by AJatNitrousOutlet
Nice looking build!
Thanks! I am sure I will be calling soon for some advice with the kit.
Old 07-21-2016, 06:59 PM
  #53
sbdgbody's Avatar
cool its running
Old 07-22-2016, 08:59 PM
  #54
cool its running
Yes it is! Just finished working on the carb tonight. It is still wanting more fuel it just keeps making more power with every time I jet it up. Made 385 @ 6700 and 344 ftlbs. I think I got the dip figured out, but I ran out of time.
385 whp 344 ftlbs
Old 07-28-2016, 06:53 AM
  #55
sbdgbody's Avatar
been to track yet
Old 07-28-2016, 02:29 PM
  #56
been to track yet
Not yet, just finished getting the carb dialed in last week. Hopefully I will get it to the track soon.
Old 08-02-2016, 05:59 PM
  #57
Old School Heavy
speedtigger's Avatar
This is a fun build. The ole' mustang ought really fly. What stall converter?
Old 11-24-2016, 12:08 AM
  #58
The converter stalls at 4200, and to update the thread the car has run a best of 10.94 @ 128 on motor. next trip I hope to start tuning the kit.
Old 02-17-2017, 07:14 AM
  #59
AnthonyLMBD's Avatar
Nice!
Old 02-19-2017, 09:17 PM
  #60
Originally Posted by AnthonyLMBD
Nice!
Thanks, I have been slacking with updates on here. Last trip to the track I put it in the single digits on a 150 shot. Changing the converter up and hope to get the 1/8 mile time down into the 5's next time out.
Quick Reply: Nitrous 5.3 build
