5.3 pushrod
Old 03-11-2016, 07:03 PM
fritzb's Avatar
Default 5.3 pushrod
jus built 5.3 from 2004 avalanche going in my 78 Camaro using comp cams thumper ca 54-602-11 used there valve springs for cam. problem I now have is to much valve lash like 80 thou so no preload using stock roller lifters and push rods and stocl roller rockersany ideas
Old 03-17-2016, 11:58 AM
gagliano7's Avatar
You will have to measure pushrod length. You will probably need longer pushrods.
Quick Reply: 5.3 pushrod
