What keeps my cam from runbing the retainer plate?
Old 04-26-2016, 01:53 PM
CasperCasper's Avatar
Default What keeps my cam from runbing the retainer plate?
Installed my tsp cam and i notice it can move slightly in and out of the motor. What keeps the cam sprocket from rubbing the retainer plate ? Does the timing sprocket help do this ?
Old 04-26-2016, 02:01 PM
KCS
Moderator
KCS's Avatar
Just oil, but aftermarket timing sets will use a Torrington bearing between the gear and plate.
Old 04-27-2016, 08:50 AM
01ssreda4's Avatar
Nothing. Absolutely nothing stops it.
Old 04-27-2016, 09:50 AM
Restricted User
JoeNova's Avatar
Chain tension, usually. The tension will force the sprockets on the crank and cam to stay perfectly lined up, and the cam won't be able to move forward or backward any.
Old 04-28-2016, 06:04 AM
vettenuts's Avatar
Oil, similar to a bearing.
Old 04-28-2016, 02:23 PM
corvet786c's Avatar
You better be careful and fix that. I would drill 2 small holes 1 on each side of the plate to lube that section. If it is not properly oiled metal shaving will develop and fall into the oil pump and your motor is shot. Ask me how I know. Mine had to be rebuilt because of this a few yrs back.
Vincihiperformance has a article of this manufacture defect on our motors.
Quick Reply: What keeps my cam from runbing the retainer plate?
