stripped rocker arm bolt
It is very important that you get this new hole and threads straight. Otherwise, the retainer bolt will be at an angle and the head will be side loaded. That will eventually lead to a failure.
Use a drill press for the new hole, and a tap guide for the new threads.
i did this and fixed the hole but it has happened to two more holes! what could i be doing that would cause this? the lifters are on the base circle when i go to torque them down. and it is only happening to left bank the right bank is having no problems.
I would not use a helicoil. Get a Timesert or Keysert and install that. I have seen way too many helicoils pull out of aluminum especially when there is a load force on them.
For the price of fixing the stripped holes you honestly could get a used head for free and just slap it on there. A head gasket, some head bolts, and a header gasket is probably cheaper than spending time drilling out the holes and helicoiling them and praying they stay in the head. I'd just replace the head since it doesn't take too long.
A properly installed time-sert is not coming out and takes 5 minutes.
