JY 2006 lq4 .. what to replace
I bought a complete 06 take out 6.0 from a 3500 express van 126kmiles a few years ago and Im getting around to making my swap in my car . the motor ran great when I had it pulled , I got to start the van up cold and watch oil pressure and coolant temp and it was all great. I had this engine in my chevelle and realized the rear main seal is bad so im pulling the motor to replace it and im swapping on a set of 243s and a second hand cam I bought from a forum member. what else do you recommend I check and or replace while the engine is on a stand? thanks
There is a member here, helicoil, that is selling complete bottom end gasket sets for a real good deal. Fel-Pro, too. Just got mine in yesterday. This would allow you to change the front seal also as well as oil pan and the cover gaskets themselves if you see the need. There is a procedure for aligning the oil pan, covers(and the seals within) and sealing up the gasket so research before you yank ot all apart. It occurs to me that if you did the covers/pan one at a time they would basically align to each other...but that assumes that the last assembler of the engine(factory or dealer) aligned it right and that's not why the rear main is leaking now.
Oil pump pickup o-ring if you drop the pan...and oil pump while you're at it. Melling makes a nice stock replacement that is fairly cheap at the typical parts stores or their 10296 is a beast(but fits with stock parts) and can be had for about $150. Comes with the o-rings though.
Nothing wring with leaving alone what you don't suspect is problematic, either. The gaskets on these all basically have embedded o-rings and are even reusable in a lot of cases(though I try not to if budget allows). If you can get a deal on the gaskets though, I'd freshen them up so you don't have the engine out again for several years..except to do big fun stuff.
If its not broken, don't fix it.
And replacing things doesn't mean it's broken, just means refreshing stuff so that you ensure a long life going forward on consumable parts. Do you only replace your brakes when they are completely and utterly destroyed/broken and your car fails to stop, or are you proactive and replace them when they start showing signs of wear?
I would take it all apart and replace bearings, rings, oil pump, valvetrain etc.
That's a little more involved but I really can't argue. I am doing this with a 100K LS2 I just pulled for heads and clutch. But I am also shooting for 7x00 RPM and want a little peace of mind. So maybe I'll step back and ask the question of intended use, future plans and desired power levels? If stock is happy for you, I think a reasonable case could be made for leaving the bearings/rings alone. But we all pay for insurance each month even though we don't wreck our cars monthly...usually.
Restricted User
I'm building my third 8-second capable engine right now, using a stock 200k mile engine. If it ran perfect when I pull them, I don't see any reason to take them apart and start replacing things. Compression test, oil change, new plugs, and add lots of boost.
Restricted User
You have to remove the heads to get to them.
If I have never heard the engine run, I usually just spend the $90 for LS7 lifters, because changing them after you've already gotten it running isn't fun in any way.
Restricted User
I've never replaced a timing chain. I've never broken one. Even at 30 PSI of boost. The hardest thing about spinning the cam over is the resistance of the valve springs. If you have springs that don't have huge open pressures, then the chain doesn't see nearly as much stress.
I would change the lifters and trays since you are changing the cam, have the heads off, and the trays are cheap. I am not saying there is some big problem with trays but I have had some start to get brittle and they at least don't hold the lifters up like they used to and at worst could crack. IDK. Cheap insurance.
Moderator
With the engine on a stand and since you're already swapping the camshaft, it would be a good time to inspect the oil pump. At the very least, clean it out and make sure there isn't any debris that could stick the relief valve.
Im not sure honestly , Unfortunatley I bought the pushrods not knowing it made a difference and bought 7.4 length . The cam is a 225/225 581/581 113+1 Lsa with I think a 110 base
