Thompson motorsports cnc 243
No I haven't seen them, but I a have a short block from them that's been nothing but great. I'd be curious to hear more about these heads as well. How much they asking?
Flow numbers
.100" 78 .100" 57
.200" 138 .200" 106
.300" 204 .300" 140
.400" 259 .400" 166
.500" 288 .500" 185
.600" 306 .600" 194
.650" 310 .650" 197
.700" 313 .700" 200
.100" 78 .100" 57
.200" 138 .200" 106
.300" 204 .300" 140
.400" 259 .400" 166
.500" 288 .500" 185
.600" 306 .600" 194
.650" 310 .650" 197
.700" 313 .700" 200
Our CNC ported 243 program is still very new, Only about 50 or so sets out there. I hope to see a few customers chime in but in the mean time if we can help you with answering any questions we are here. I look forward to the opportunity to work with you.
Thank you HCI2000SS for the feedback. We always appreciate it.
Thank you,
Kyle
972-853-2450
Thank you,
Kyle
972-853-2450
From them
We offer the full stage 1 port for $750. This includes the following:
CNC Port intake and exhaust runners
Face intake and exhaust surfaces
True valve cover rail
Surface heads
Cut seats
Grind supplied valves
New cup type or hat type seals
Vacuum check heads
Assembly and disassembly of heads
Surface heads
Cut seats
Vacuum check heads
Thanks for the confidence thunderstruck507, If you are ever in need of that short block please give us a call so we can get you set up.
The heads are flowed on a new superflow flow bench, We just paid superflow to verify and re calibrate our machine last month as well prior to releasing the flow numbers. We are very pleased and proud of what we are able to achieve with our heads.
Gotcha. Based on the chart above these 243's flow close to my PRC 5.3 heads. With that said I'd imagine they'd do well on the TMS 370. What I immediately noticed by swapping these heads to the 370 from the LS1 was a broader and more powerful area under the curve
Just curious, How did you like it on the ls1? how much more of an increase did you see? I'm in the middle of a ls swap now on 88 Monte. The motor is literally brand new and was planning on rolling with the LS1 for awhile and save up for something "bigger and badder" later on
