Iron Block Cominations
Old 06-17-2004, 03:36 PM
Just Floor It's Avatar
Default Iron Block Cominations
What are some cubic inch combinations that you can make out of the 5.0L Iron block? Can you make a 427?
Thanks
Old 06-17-2004, 04:03 PM
kumar75150's Avatar
its a 6.0 L block and u can make a 427 out of it.
4.06 bore x 4.125 stroke = 427
Old 06-17-2004, 04:18 PM
Sweet! I havent heard really good things about the 4.125 stroke though...
Old 06-17-2004, 04:26 PM
kumar75150's Avatar
I'm using it on an alum block. 16k miles and no problems
Ben R's Avatar
If you're wanting to use a 6.0L Iron block, a standard 408/410 will be sufficient. Boring a 6.0L block any more than .030 can lead to cylinder walls that are too thin. It all depends on it's intended use, of course.
Old 06-17-2004, 04:36 PM
Cool....What about the 4.030 bore?
Old 06-17-2004, 04:43 PM
Ben R's Avatar
A stock 6.0L block has a 4.000 bore, so a 6.0L block bored .030 over has a 4.030 bore. Use that in conjuction with a 4.000" Stroke and you'll get 408 Cubic Inches.
If you want a 410 then you bore the block .040 over and use a 4.000" Stroke.
Old 06-17-2004, 04:44 PM
Mike K.'s Avatar
that bore is fine.
