LS6 reliability/ power mods for road course race car?
So the title pretty much explains it all. i have a LS6 engine in a RX7 that is currently being built for road course and time attack.
I am new to this V8 game and making power reliability is a must with this new setup.
I have learned that trunion kit is a must and the motor has the following so far.
239 cam, 601/ 604 lift
7956 Comp Push Rods 7.450 .080
7/8" long tube headers (JTR)
Fidanza Lightweight LS2 flywheel
LS7 Clutch
I am thinking of selling my LS6 intake for Fast 90 and throttle body as well as run bigger injectors. Are there anything else that i need to know in order to increase reliability and power for road course use?
LS7 Clutch
Moderator
Aviad has some good dry sump kits that are pretty economical. Their entry level kits use the OEM pump for pressure and an external pump mounted on the passenger side cylinder head for the scavenge. The external pump is even run off the accessory serpentine belt. It's not the best dry sump out there (again, entry level kit) and it doesn't fix the LS oiling issues, but it's a good band aid.
The following users liked this post:
Homer_Simpson (12-04-2021)
thank you everyone. oil control is important. i see. i have accusump coming in and Improved racing oil pan baffle
would this be sufficient?
In terms of oil cooler, how large of an oil cooler are people running?
how about in terms of performance? i would like to rev it out as much as possible. what kind of setup in the head are track guys running? i would like to keep the bottom end stock for now
LS1Tech Sponsor
Also curious as to which body style RX7 you have?
I would back the cam off some, 239 may gain some up top but low 230s will likely help mid range while giving very little up in peak HP. I would run a 3/8" push rod, at minimum 11/32".
Most road racing requires engine RPM's spending the majority of the time in the 3000-4000 RPM range which causes many harmonic vibrations so that much time at those RPM's cause timing chain breakage especially true without chain dampers so t-chain damper is a given for sure . Good luck and stay safe
Ishin, please for the love of god stop modding the car before even doing ONE event on it -_-. You're wasting money on things you don't need.
1) Keep the stock intake and run OEM GTP injectors.
2) Go to a stock LS6 cam because that'll be PLENTY of power starting off.
3) Do what I did with oil control, + your accusump you'll be fine.
4) K.I.S.S. - Keep It Simple, Stupid. More mods, more HP, more tq, more heat = more problems.
5) Get an ATI Damper, I have this.
6) Mellings 10295 High Pressure Pump - I have this.
7) Improved racing baffle and crank scapper - I have this
8) Biggest oil cooler you can fit, I have the Earls 42 row Wide, 44200 p#.
9) Drill oil pan return side casting flash near oil filter.
10) Drill/slot the lifter trays.
11) Run M1 15-50 oil.
12) ARP rod bolts, require rod-resizing but will bullet proof high revs.
Literally, like I've been telling you, I've been through this, there is no need to reinvent the wheel.
I was going to recommend this as well. I think this is a must on a road race car due to the harmonics in the upper RPM band that come into play with this type of driving. Katech still had some of the original dampers from GMPP, not sure if they have any left but might be worth a call.
but primary goal is to make it reliable at the moment ofcourse. i will be getting the damper, high pressure pump, crank scraper, and of course a giant oil cooler
