Need Help with possible engine damage
While changing my oil on my 2002 Formula, I didn't realize the old oil filter washer was stuck up against the block. So when I put the new oil filter on and filled it with oil, as I started it to lower it off the ramps, all the oil came out the filter where the extra seal was. I had to drive it back up the ramp and remove the extra o ring. I refilled it. I had to replace most of the oil. Total run time was 4 or 5 seconds while it was coming out. 3-4 seconds to get it back up the ramp only halfway, then I shut her down. Wondering if I damaged any bearings. What do you think? Oil pressure is normal.
You're getting good advice here.
While you never want to run an engine without oil, it's pretty amazing how long they will run without it if you aren't loading it up. I used to change the oil in all of our family's vehicles growing up. I literally forgot to fill my mother's Grand Marquis (4.6L 2V) on time and drove it around the neighborhood(soft on the throttle) at about 40K miles. No oil. Once I realized, I babied it back and filled it. We got over 100K out of that engine and it was still running very smoothly and burning no oil by the time a wreck finally ended it.
As Steve said, good oil pressure is a sign that your engine is okay, which it most likely is. But just in case, it definitely wouldn't hurt to run the engine for a bit then cut open the oil filter to check for metal shavings. I personally would like the peace of mind that inspecting the oil filter would bring
It was pretty cool seeing it run with no tin, or balancer.
