Cam specs for all out blower application (700+ rwhp)
Ok guys heres the deal. First, i have to admit the car in question is (gasp) a Mustang. Problem is none of the people on mustang boards will tell me what i need to know. I know i can depend on this site for great tech info. The car is a '99 Saleen S-351 (#30 of 45 built) with quite a few major upgrades from stock. As is sits, the intakes and cam are stock however. As we just upgraded the blower to a cog driven T-trim, we have the new intakes sitting on the floor of the shop (its boss mans car, he owns the shop i work at) and before we get the new tune ironed out we want to get the cam swapped. Its making 535 rwhp now with a slack tune and 13 psi. We hope to go 18-20 psi for near to 700 rwhp. Now my question is this, what makes a top notch cam for a nasty blower setup like we have. Its not even close to a daily driver so driveability is not an issue. Any info would be greatly appreciated. Im looking for specific specs if possible. Thank you in advance.
TT-TECH Veteran
Yeah I am with dug. I would try some more knowledgeable poeple on FORDS. And top notch cams are a personal choice. I have a 224/230 on a 114. But that is LS1 and just like any other application it should be model specific a LS1 is not like an old SBC motor at all and reacts differently and so would your Mustang. Good luck!
I would expect to pay a reasonable amount for the advice (free advice is usually worth everything you pay for it) either as a fee or by buying the cam and valvetrain parts from the designer. This has worked for others with Chevy engines in the same or higher HP range.
My $.02
Try giving Combination Motorsports a call. they were very knowledgeable about cams when I spoke to them. I'm not sure about their Ford stuff but their homepage states that they also deal with it so they should be worth a shot???
Troy
Troy
