Question on rod and pistons
Please before I start. I had a search and tried to find the answer I am not great on computers so please don't abuse me if this has already been answered. My question can I use the standard rods with arp bolts and use Pistons designed for a 6.125 rod? I am teaching a senior shop class and fund the build myself so I am trying to get out of it a bit cheaper. I eventually will run a turbo, there seems to be a lot better selection of affordable Pistons with the 6.125x6.098 spec forged pistons
Moderator
You can as long as the piston and rod are meant for the same diameter pin. The stock rods are meant for a .944" pin while most of the aftermarket pistons for a 6.125" rod are also for a .927" pin. If you have a press fit rod, it is possible to hone the piston pin bore out to use the larger pin.
