I have oil leaking after cam install
Old 06-20-2004, 08:11 PM
2000SLVR_Z28's Avatar
Default I have oil leaking after cam install
It looks like it is dropping down on the drivers side header. What would be causing this? Did we not put the valve cover seal back on properly?
Old 06-20-2004, 08:18 PM
LS1Tech Sponsor
Slowhawk's Avatar
I would check the valve cover seals first.
Old 06-20-2004, 10:24 PM
DrkPhx's Avatar
You probably torqued the valve covers too tight.
Old 06-20-2004, 11:21 PM
Kevin 276's Avatar
Like someone else mentioned, what did you torque down the valve covers? Did you replace the rubber gaskets for any reason? I would remove that valve cover and take a look?
Old 06-21-2004, 12:35 AM
BadAndy's Avatar
Yeah sounds like The valve cover. No big deal. Pull the cover and check to see if the gasket is seated properly in the groove in the cover. Sometimes they like to pop out in random places if off the head for a while.
Old 06-21-2004, 01:29 AM
Ferocity02's Avatar
Yeah, the valve cover seals are hard to get seated. And don't over-torque them either.
Old 06-21-2004, 03:05 AM
BriGuy's Avatar
Is it dropping on the header at the back or front? Another thing to just check I think would be the pcv valve piece that connects to the back of the valve cover maybe.
