LS6 Ticking when warm and under hard cornering - Page 2 - LS1TECH
Thread Tools Search this Thread
Old 03-06-2017, 02:33 PM   #21
Interesting, if you want to try something different that won't hurt a thing go to Walmart abd get a bottle of transX auto matic trans conditioner and put 3 ozs in your engibe oil. It won't hurt anything but it will help seal and oring trouble and clean the lifters.
Darth has a good idea, maybe you have a pin hole in the pickup tube or crack.
RockinWs6 is offline   Reply With Quote
Old 03-06-2017, 02:35 PM   #22
Quote:
Originally Posted by Darth_V8r View Post
Try overfilling the oil by a quart and see if it helps. Almost sounds like a small hole in the pickup tube above the inlet screen on the left hand side. When you turn hard left, all the oil goes to the right.
if this were the case, should I see a pressure drop while turning left? I think i would. Going to test this as well.
VerdeZ28 is offline   Reply With Quote
Old 03-06-2017, 02:42 PM   #23
You could easily add 2 qts without any issues. I was running 7 qts for a while because I was on it hard in tight turns.
Old 03-09-2017, 07:41 AM   #24
So after further testing I think the tick that comes up while turning hard left is not engine related. Seems to be coming from the rear and I could hear it clearly on my gopro. I tested this while driving in a circle at decent Gs and noticing it sounded like its coming from behind. I shifted to get the rpms down but maintain the speed and the tick did not change with the rpm. So I guess thats a good thing.
The engine itself still has a sewing machine noise. Only comes up once oil temps are over 140F. Ill try to post video of it soon.
Old 03-13-2017, 06:51 AM   #25
1bdbrd's Avatar
Would this be ok to do on a higher mileage engine? Mine is dead silent cold but after warming up has what I think is a lifter tick that gets louder after a rev when the rpms are coming down. Then its a steady faint tick at idle. Engine internally is completely stock as far as I know.
1bdbrd is offline   Reply With Quote
Old 03-13-2017, 10:23 AM   #26
Darth_V8r's Avatar
Quote:
That's good! I'd still run it a quart overfilled to make sure that pickup stays submerged.
Darth_V8r is offline   Reply With Quote
Old 03-13-2017, 03:02 PM   #27
Quote:
this is almost exactly like my car. If you rev hard, lets say up to 4k, as it comes down its loudest from 1700-2200 rpm range.
Old 03-15-2017, 10:58 AM   #28
Docrocket1967's Avatar
On your theory number 2 if this was the case your oil pressure would be much much lower. Ask me how I know lol. If the o-ring on the pickup tube is pinched or is an issue it will cause bad oil pressure and noises only after warming up. When my car was cold it had great pressure and no noises.
Docrocket1967 is online now   Reply With Quote
Related Topics
Thread Thread Starter Forum Replies Last Post
Loud ticking Mike Gilsdorf Generation III Internal Engine 2 02-08-2017 07:45 AM
Help diagnose this tick/tap sound, video inside Ferocity02 Generation III Internal Engine 14 11-20-2012 11:39 AM
Ticking after head/cam swap... longer pushrods? Ferocity02 Generation III Internal Engine 3 10-10-2012 12:25 PM
Ticking noise after warm up low oil pressure wicked87svo Generation III Internal Engine 10 08-04-2010 11:48 PM
i'm stumped..... ticking noise? ryeguy187 LT1-LT4 Modifications 19 05-02-2007 07:14 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
    Get answers from community experts
What's your question?
Send
