5.7 coming out 6.0 lq4 going in, what cam?
Hey guys so my 5.7 gave up on me and I'm not sure what happened but I got a smoking deal on a 6.0 lq4. It was a 2000 block so I picked up a 12552216 cast crank and some ls2 rods, I plan on getting some lq9 pistons this week. My question is I am going to be swapping my prc 2.5 ls6 heads that were milled .20 and hopefully my tsp v3 cam, I'm hoping with the heads being milled and switching to flat top pistons will net me some good compression and hp but should I stick with my tsp v3 cam or should I consider other cams? I want to take advantage of the displacement of the 6.0 and the added compression my goal is close to 500rwhp, my 5.7 with the tsp v3 made 440whp. I called tsp and they said with what I'm doing with the 6.0 and the heads already being milled that to have enough ptv clearance I could only keep the v3 or upgrade to their tsp v4. So are there any other cams out there I could get away with that wouldn't give me issues ptv clearance wise and could get me somewhat close to 500rwhp?
Anyone able to give me some insight, I've been searching ls1tech for two days straight and can't find a situation or question similar to mine to get an idea so any help would be great
Would it make a difference if I bored it out to a 370 and get a set of ls3 heads with a ls3 cam? Or will boring it to a 370 not really make a big difference?
Old School Heavy
Thinking of making this a 370 build could I technically still clear with those heads?
Old School Heavy
What about this? https://www.texas-speed.com/p-1156-t...-camshaft.aspx
