About to drive my car into a lake
So all joking aside im about to lose my mind.
I a while ago developed a very slight tick. Almost 2 years ago. Car drives usually pretty good.
The tick doesnt get louder or change much with engine acceleration, engine braking or at idle. It does speed up alittle but barely.
The tick used to be louder and less consistent. Usually long periods of idling would bring a flashing check engine light. As soon as I would accelerate it would disappear. The Light anyways.
I replaced the pushrods thinking maybe one was slightly bent. When pulled 1 or 2 seemed just a hair off. Extremely minor but replaced. The sewing machine noise was way quiter but the tick and the light was still there.
I was told it may all be from a leaking exhaust gasket. I pulled the driver side(where i feel the noise is coming from) and sure enough it had soot marks indicating a leak. Once replaced the tick got quiter, but the check engine light would come on more consistently and the car now idles or runs noticeably rougher when the check engine light is flashing.
I get the codes run, and only have a Random cylinder misfire. I have full exhaust and the egr codes are there but whatever.
Anyways, I replaced Coils, plug wires, spark plugs, O2's and still get random cylinder misfiring. Nothing new.
All plugs looked light brown IE lean but not crazy lean. All except cylinder 3. That one looked alittle rich/oil on it. I have seen oil fouled how are you running kind plugs not have issues. This one was lightly covered with alittle oil and looking the color of a rich plug.
I am under the impression maybe a valve isnt seating nicely or a lifter may be sticking. HOWEVER I really dont see any power lose, the light and noise are anything but consistent and when cold I hear nothing. Once the car is driven or left to idle for a few minutes will I see the light or hear anything.
Again usually the noise and light go away on hard acceleration but the noise is fairly quiet and maybe I just cant hear it.
With everything said in mind I am beginning to think I may have a couple bad or clogged injectors. The ticking noise is not a tapping noise and isnt a pulley(noise is present with no belts on) and I know its not piston slap as it sounds nothing like my vette that had piston slap.
Sorry for the long post but this has been plaguing me for over 2 years.
Or could also be a arcing spark plug maybe a cracked insulator or a bad wire arcing. Checking that at night time you might be able to see an arc coming from the source. It'll prob be something dumb in the long run.
I would imagine new plugs and wires msd and ngk wouldnt give the same results as old oem/old msg plug wires and old plugs think bosch.
Moderator
Received 1,835 Likes
Have you done a compression check on all four driver cylinders?
Also if you have a capable scanner, you can disable one cylinder and see if disabling one particular cylinder has less or no effect vs the others
vacuum leaks......still have the stock PCV system? intake gaskets....they get hard and brittle....O rings on injectors....hard and brittle.....exhaust leaking from loose or missing bolts....I had 2 broken bolts on mine ! ...gasket behind throttle body....hard and brittle....compare any of the old gaskets to new and pliable ones and you will see what I am talking about
