Anyone ever had to change their knock sensor??
Old 06-24-2004, 09:36 AM
James Creasy's Avatar
Default Anyone ever had to change their knock sensor??
If so, how long does it take, my mechanic told me 3 hours total. Also if you have changed your sensor, did you notice any difference when you replaced it? I was told a guy at my local track gained 3 tenths simply by a replacement.
Old 06-24-2004, 09:43 AM
BTL FED's Avatar
The only way that you would gain anything is if you had a bad knock sensor and it was pulling timing. As fas as for replacing them, it isnt hard, just pull the intake off, and the 2 sensor are right there, squeeze the plug to detach it from the sensor, and take a socked and unscrew the sensor
Old 06-24-2004, 10:34 AM
Taphee6's Avatar
Torque the knock sensor to 15 ft lbs. Also, there is a SB out by GM that states to put a heavy bead of rtv around the rubber grommet. This is to divert water away from the knock sensor valley.
Old 06-24-2004, 11:33 AM
minivette's Avatar
What they said.
Old 06-24-2004, 12:02 PM
strokedls1's Avatar
Easy install and should take half that time. If it takes him 3 hours he doesn't know ls1's.
Old 06-24-2004, 02:13 PM
Thanks for your replys, I know I can do this change. what about the issue with the timing, because the sensor is throwing a code, isn't that the same as a bad sensor even if it is good? And wouldn't your engine compensate for it either way(loss of power)?
About my mechanic, I think he likes to charge a little high these days, I like him, and he's good, but I'd rather do things myself now.
Old 06-24-2004, 05:34 PM
minivette's Avatar
Once you replace it and there are no codes being thrown, everything should return to normal.
Old 06-24-2004, 06:42 PM
greatwhite99's Avatar
One thing of note: before you reassemble make sure the wires for the sensors are not going to be in the way of the intake when you put it back together. I put my intake back on an pinched a wire going to the sensor and had to take it back apart to fix it.
Mike
Old 06-24-2004, 09:43 PM
Hopefully I can do this simple project with ease, my car seems to be cursed when things have to be replaced . But thanks for the advise.
