Best cam only cam for stock bottom end ls1
Old 02-17-2017, 09:11 PM
ManMuchwano93z28's Avatar
Default Best cam only cam for stock bottom end ls1
Hey guys I know this has been asked a million times on here I searched and couldn't really get the anwser I was looking for so here's my situation. I have a 01 z28 a4 I wanted to know what cam will give me the most power don't really care about drivablillty as long as it makes power Car is currently equipped with tsp 1/78 long tubes tsp true duals slp lif with a ls6 intake I have these parts on my self at home prc ported 243 off a trail blazer with btr springs ls2 timing chain ls7 lifter lifter trays 42lb and hr injectors fast 102 intake and tb fuel pump 4K stall with a trans cooler And wanted to know which off the self cam will give the most power. And My gear is a 2.73 gears. But I'll change that after I blow the 10 bolt I was thinking about btr stage 4 but I also heard of people running into piston to vavle clearance issues with that one looking to be in the 10 sec range in the quarter and then spray a 150 shot. And I won't mind spinning it to 7k. Hopefully some of the cam only guys can give me some help. Thanks
Old 02-20-2017, 06:22 AM
TRMIN8R's Avatar
Tsp ms3.
Old 02-20-2017, 07:29 AM
HaulinHawk's Avatar
My old G5X3 had done me ok .
Quick Reply: Best cam only cam for stock bottom end ls1
