any G5x3 guys running heads without having to flycut pistons?
Old 06-24-2004, 11:56 PM
Stone0fFire's Avatar
Default any G5x3 guys running heads without having to flycut pistons?
i want the g5x3!
but i want to add heads later.
do i really have to flycut the pistons?
how much is that?
is there anything which is pretty damn close to a g5x3
but i can put heads on?
what are the specs to a g5x3 anyway?
is a tr230 close?
i think the t-rex cam is too much for a daily, right?
i heard the x3 can be made to be okay in a daily driver.
i mean close in performance in the the quarter mile,
not peak hp or anything petty like that.
thanks!
Old 06-25-2004, 12:48 AM
jrp
SN95 Director
jrp's Avatar
umm, did you miss the bazillion x3 cams threads in the last week or so . the 114 will fit with no flycutting, the 112 needs to be cut if memory serves me right. this is assuming unmilled heads.
Old 06-25-2004, 11:31 AM
6600 rpm clutch dump of death Administrator
J-Rod's Avatar
Correct.
The X3 is also much larger than the TR230.
Also, remember, although it is supposed to clear with no flycutting on a 114, you should always check your setup before final assembly as you should with any cam install.
Old 06-25-2004, 04:37 PM
sorry!
i just read the G5x3 vs. TRex thread
someone mentions mandatory flycutting on 112,
and not having to on 114.
guess i know what im getting now
now..
if only i had someone to help out with the install..
Old 06-25-2004, 04:40 PM
6.0vette's Avatar
Does the x3 114 have less ptov clearance then the x2-112.
I have been considering the x3 but im at 70 thous clearance
on the intake side with x2.
Old 06-25-2004, 05:04 PM
PREDATOR-Z's Avatar
Forget the X3 then, that's the limit.
