382cid stroker rebuild, ideas what to do? - LS1TECH
Thread Tools Search this Thread
Old 02-28-2017, 04:26 AM   #1
Default 382cid stroker rebuild, ideas what to do?
I have currently my frieds 382 stroker taken apart in my workshop, and iīm bit lost on ideas what to do with this.
So what i have, i think itīs from Mosler racecar.
LS1 block, damaged
JE3814 flat top pistons, 3.898, pretty worn out, about 0.007"
6.125 rod, probably Oliver, atleast bolts are
4.0" crank, maybe Callies
243 heads
ASA cam, so 0.525"/0.525" 226/236, LSA 110.
LS6 springs
LS6 intake
I did also have so neat stuff, dry sump system, Ati fluidamper, 7.25 clutch etc. Specs seem to pretty much match what iīve read from mosler engines.
1 piston pins clip has been loose, and there has been bad sratches in 1 cylinder, owner had engine taken apart and someone honed scrathes off, probably without stess-plates and itīs now 0.015" over, so this block is junk if imīm correct.
Owner wants healthy N/A engine +450whp, that has room to add boost later if needed.
Plan was to source 6.0 block, and build this to that but here comeīs what iīm guessing for.
What are those 243 heads and intake capable of in 408cid stroker, does that 4.0" go to waste and just shorter engine age in matter of piston wear.
ASA cam, i donīt quite know what to think about that, low lift and big LSA, i know thats not good for boosted aplications, but where it draws line with this in N/A engine.
What would you guys do?
Mikko is offline   Reply With Quote
Old 02-28-2017, 05:33 AM   #2
KCS
Moderator
KCS's Avatar
LS1 block, damaged
243 heads
LS6 springs
LS6 intake
Piston wear is really going to depend on block prep and piston design. There are some crappy designs out there on the market and if you forget to debur the bottom of the cylinders, you're going to have issues. I like Wiseco, personally.
Unported 243 heads are plenty capable for a 450whp goal. They have been known to make over 500whp in some really well sorted out combos, even more with a good CNC program run through them. The extra cubes underneath will certainly help.
KCS is online now   Reply With Quote
Old 02-28-2017, 08:49 AM   #3
I thought 243 vs. L92 head difference is bigger. Well good
What about Ls6 intake, whereīs the limits of that?
What cam would be suggested if iīll stick with originall plans 408cid and those 243 heads.
So compression ratio maybe in 10.5 level, so thereīs room to drop it a tad with thicker gaskets if there comes boost later, and overal cam. Good for N/A but also should work for boosted application.
Old 02-28-2017, 08:50 AM   #4
Darth_V8r's Avatar
I think that the ASA cam might be too small for your 4" stroke, and I think you'll end up disappointed. You should probably be looking more at cam durations like 232/240
JMHO
Darth_V8r is offline   Reply With Quote
Old 02-28-2017, 09:20 AM   #5
kinglt-1's Avatar
There is a member here running 10's NA with a Howards ASA cam & 1.85 rockers in a 346. It's a fairly capable cam, just throw some 1.8 rockers on it and bring the lift up. It would work OK with a centri blower but would not be optimal.
That being said I would change cams to optimize the setup.
kinglt-1 is online now   Reply With Quote
Old 02-28-2017, 09:21 AM   #6
230/240 area and probaly ~0.620 lift what i had in mind...? But what about LSA, is 112 suitable compromise with that boost in mind, or 114? Dunno is it ever going to happen, but owner wnatīs to keep that door open.
Edit:
That last post did come while i was typing this, yes 1.8 rockers was one thing on mind.
Old 02-28-2017, 09:27 AM   #7
kinglt-1's Avatar
Just get the Brute Speed Blower cam.
http://shop.brutespeed.com/Brute-Spe...d-Camshaft.htm
Old 03-14-2017, 01:59 AM   #8
As this is probably going to be N/A for a while, we decided to go with N/A cam, and swap it later with turbo if itīs going to happen.
TSP recommended this and seems nice.
http://www.texas-speed.com/p-1151-te...-camshaft.aspx
What do you guys think, how much power iīm going to gain in this kind of engine compared to ASA cam, quite a lot money afterall with springs etc.
What about that ls6 intake, any real gain for swapping etc to Fast 102
Btw. that asa cam, that would be leftover, too big for my stock LM7 budget build?
Old 03-14-2017, 05:06 AM   #9
99 Black Bird T/A's Avatar
I would make cam choice after selecting intake manifold and deciding what to do with the 243 heads. Properly ported 550 rear wheel is possible with sorted car and supporting mods with the 243's. I would pick the cam based off of what the heads and intake end up being.
What's the budget for rebuild?
99 Black Bird T/A is offline   Reply With Quote
Old 03-14-2017, 05:39 AM   #10
Tuskyz28's Avatar
James Day (TXCAMSS) had a 408ci shortblock topped with ported Greg Good 5.3 heads. That car eventually ran 10.00 with a circle D stalled 4L60E. Ported Fast 92mm intake..... I say a 243 headed 408ci certainly has the power to hurt some feeling.
Tuskyz28 is online now   Reply With Quote
Old 03-14-2017, 03:26 PM   #11
LS1Tech Sponsor
Martin Smallwood's Avatar
I would be glad to help assist you in which route you should take for your customer's wants and needs.
You can email me or give me a call if you wish.
Martin Smallwood is offline   Reply With Quote
Old 03-15-2017, 08:28 AM   #12
big hammer's Avatar
Imo 243 heads, ls6 intake and an ASA cam would be a pretty weak combo on a 408
big hammer is offline   Reply With Quote
Related Topics
Thread Thread Starter Forum Replies Last Post
The history of the ls1 Zerokube General LSX Automobile Discussion 19 05-25-2012 09:27 PM
what springs to run with asa cam? gmcondub2s Generation III Internal Engine 19 09-01-2011 04:25 PM
Anyone running High Boost #'s on an LS1? Light84vette Generation III Internal Engine 19 03-29-2003 08:43 PM
**LS1tech.com fastest NA LS1 list ** GeorgeC Drag Racing Tech 43 03-23-2002 03:28 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
    Get answers from community experts
What's your question?
Send
