LS6 no oil pressure - Page 2 - LS1TECH
LS6 no oil pressure
Thread Tools Search this Thread
Old 03-13-2017, 09:56 PM   #21
Mercier's Avatar
Hadn't seen that particular video before. I thought it was the pitch for their oil priming system(visible on top of the engine in the first scene) but then it wasn't. That's a good idea. I was referring to pressure-filling through the engine, but that may not be necessary.
Mercier is online now   Reply With Quote
Old 03-17-2017, 05:36 PM   #22
New pump in, pinned the crank, installed front cover and balancer, turned the motor over with the starter and had oil pressure on my mechanical gauge after ~10 seconds of cranking. Time for reassembly. Hopefully rest of the process is smooth sailling.
onspeed is offline   Reply With Quote
Old 03-18-2017, 02:58 AM   #23
Mercier's Avatar
Congrats; nice that it was fairly simple...even if it still required a lot of work. How much pressure did you achieve just with the starter?
Old 03-18-2017, 08:50 AM   #24
40+psi with a small leak on the gauge fitting. I didn't bother to see how high it would go. I fired the car really briefly last night and it was around 60psi cold idle.
Related Topics
Thread Thread Starter Forum Replies Last Post
Low Oil Pressure in my Daily Driver--Please Help! 68SS98Z28 Generation III Internal Engine 25 04-18-2016 06:22 AM
LQ4 knocking after rebuild. JC316 Generation III Internal Engine 5 01-02-2016 04:50 PM
first drive: things went great, then oil psi issues Ryanbgb22 Forced Induction 10 12-26-2015 05:28 PM
Oil pressure issue with new ERL 434ci engine. Snyper Generation IV Internal Engine 44 03-30-2013 09:02 AM
Oil pressure LOW at high temps LSGunZ28 Generation IV Internal Engine 34 10-20-2009 05:43 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
    Get answers from community experts
What's your question?
Send
