Oil filter bypass on LS1 pan.
LS1Tech Sponsor
I have found metal in areas there shouldn't be. Like the turbo bearing. Which is being fed post filter and shouldn’t have aluminum bearing material in them… yet some is sneaking by. Same with the mains after a season of racing I think more material is getting bypassed than should.
It's something I wish to eliminate, since I run elevated pressures. The system is not longer factory and no longer functions as it was designed to IMO.
LS1Tech Sponsor
It's fine to remove it, most filters have pressure bypass valves anyway.
LS1Tech Sponsor
Yeah it looks ok. But it's okay to remove it if you want to. As far as how to remove it, I've never tried so I can't help you. I'd just start trying to pry it out and maybe drill it and break it into pieces if that doesn't work.
LS1Tech Sponsor
Hi,
We have the Bypass Delete plugs.
http://www.saccitycorvette.com/BilletBypassPlug.html
You have to remove the oil filter adapter and then pry it out. The right size easy out will help. Get it to lock
in and twist and pull.
And since the are worried about unfiltered oil getting into the system we
also have the precision fit Billet Barbell that keeps unfiltered oil out and improves oil flow.
Here is a link with more info and videos.
http://www.saccitycorvette.com/Billet-BarBell.html
Thank you,
Christian
Thank you,
Christian
__________________
Don't forget to check out our products at www.saccitycorvette.com
If you like our products, tell others! If not, tell us!
