Any dyno comparison info on 4.8 with 799 vs 706/862 heads?
Old 03-13-2017, 08:07 AM
Forcefed86's Avatar
Default Any dyno comparison info on 4.8 with 799 vs 706/862 heads?
Which combo do you think would make more low end power (say below 4k)? 9.5:1 and small valve heads? Or 8.8:1 and large valve heads? Curious if the 799 is an “all around” upgrade or if you lose low end power compared to the smaller valve/CC heads.
It looks like the newest 4.8 (L20) comes with 799’s and is 8.8:1 compression VS the older 4.8’s (LR4) running the 706’s at 9.5:1. I’m guessing if GM decided to bolt the 799’s on the newer engines (even with the compression loss) that they didn’t give up any low RPM performance?
Reason I ask is I have a 4.8 short block. I’ve got a set of 799’s and 862’s. Will have a 216/222 @ 111 cam. .56x lift with 1.8 rockers on an LS6 intake. This will be a turbo setup. I’m running a pretty darn tight converter though (9.5 PTC with 14 stator) and a large 1.32 T6 S480 turbo.
My previous 4.8 (same tight converter) with 706 heads would barely light the 1.25 T4 S476. With a 212/212@112 .565”. But I ran a 2.5” hotside then. Now I run a 2” divided hotside. I’m not really worried about overall peak power as much as being able to get into boost initially. (trans brake drag car)
Old 03-13-2017, 12:46 PM
mOtOrHeAd MiKe's Avatar
Location: Ottawa Ontario, Canada - where arguing "DA" is for the slow and weak...
Not exactly apples to apples... but, I will be putting 241s on our Gen III 4.8L. I will take a lot more cylinder filling ability over a minute amount of compression.
Also, I plan on doing home brew thick MLS gaskets using the guts of the old gaskets. Drill out the rivets and stack 'em up. Might lose a bit of compression there too.
Old 03-13-2017, 01:08 PM
Forcefed86's Avatar
I would too generally, but this is a temporary engine being dropped in front of a converter that’s WAY too tight. Speced for a motor that easily made 400ish ftlb at low rpm. It might still be fine with the smaller 2” hotside. Hoping I can make it work without nitrous. I didn’ta want to have to deal with the weight and hassle.
Heck I wouldn’t have hesitated to throw my 317 heads on it if I could drop a loose converter in there. Hoping to have a LSX block in it come next spring though so I didn’t want to buy another $1000 converter.
-thks!
Quick Reply: Any dyno comparison info on 4.8 with 799 vs 706/862 heads?
