rocker arm bolts /AI 226 heads, blue thread lock OK to use? - LS1TECH
Thread Tools Search this Thread
Old 03-14-2017, 06:17 PM   #1
RollinSScamaro's Avatar
Default rocker arm bolts /AI 226 heads, blue thread lock OK to use?
This may be a dumb question but I keep finding mixed answers in searches. My machine shop installed my rocker arm bolts with blue thread lock on my AI 226 heads.. I was thinking they needed thread sealer since they are ported and polished but not sure why? Will they be fine how they are or should I have him remove them and apply sealer?
Also, what's this I keep reading about RTV on intake bolts? Saw that while searching and don't quite understand that.
I am picking up my motor tomorrow so I'm hoping to figure this out beforehand.
Thanks guys!
RollinSScamaro is offline   Reply With Quote
Old 03-14-2017, 06:22 PM   #2
kinglt-1's Avatar
I use hylomar blue sealant.
kinglt-1 is online now   Reply With Quote
Old 03-14-2017, 06:49 PM   #3
Will the loctite hold or will it leak without the sealant?
Old 03-14-2017, 11:54 PM   #4
Super Hulk Smash
JakeFusion's Avatar
Blue Loctite is a sealant. I ran with it for a while.
I switched to just the regular Thread Sealant last go around. No issues. Makes removing the bolt a little easier.
JakeFusion is online now   Reply With Quote
Old 03-15-2017, 06:30 AM   #5
If you will look closely at your heads when they port them they open the bolt hole when they remove the hump in the intake runner, thus the need for sealer on the rocker bolts. FWIW
cookseyb is online now   Reply With Quote
Old 03-15-2017, 06:40 AM   #6
vettenuts's Avatar
I have been running blue Loctite on my rocker bolts for years without any leakage issues on my AFR heads.
vettenuts is offline   Reply With Quote
Old 03-15-2017, 07:38 AM   #7
Sounds like the thread sealant may be the best option, but the blue thread also works. This is kind of what i was finding in searches also.. I just wanted to make sure before picking my motor up since he used blue loctite, don't think he understood why i was asking for sealer.
Do i need to apply any RTV to my intake bolts when i install them? That was the only other thing i kept running into while searching, and i've never heard of doing this before. I thought i was good throwing new intake seals on and just bolting the Fast intake on?
I appreciate the input guys!
Old 03-15-2017, 08:06 AM   #8
Super Hulk Smash
JakeFusion's Avatar
Nope. No RTV needed. The plunger washer that they use seals them up well. Just don't overtighten them.
And as I said, Blue Loctite is a sealant as well. It works fine. It does take a little more oomph to remove them. So I went to just regular white Thread Sealant the last time. It will keep the bolts from moving as well but won't "lock" them in as tight for removal. I use aftermarket bolts so I didn't want to strip the socket cap on them.
Old 03-15-2017, 09:57 AM   #9
Blue loctite works well and makes very little mess. RTV type sealant is messier to clean up when and if you take it back apart. Bot work well.
unit is offline   Reply With Quote
Old 03-15-2017, 11:34 AM   #10
Awesome! Thanks for the info guy. I will just roll with it for now. If i run across anything else i may hop back on here and get clarification.
I'll throw a thread together with the build here eventually and hopefully have dyno results sometime in April.
Old 03-15-2017, 01:22 PM   #11
BlackDuk98's Avatar
I use Permatex high temp thread sealant on the intake rocker bolts, and always used ARP thread lube on the exhaust side with no problems. Never had a bolt loosen.
What I would not reccomend is ARP thread sealant. It does not like oil and the oil eats through it and starts leaking. Bro built a motor and used it where nessecary and it leaks at all those points. Second time built we used the permatex thread sealant and ne leaks ever popped up.
BlackDuk98 is offline   Reply With Quote
Related Topics
Thread Thread Starter Forum Replies Last Post
Head bolt install - ARP projectX Generation III External Engine 7 06-17-2014 04:06 PM
What bolts to use Thread locker on. lt1_2buku LT1-LT4 Modifications 10 09-08-2012 08:44 PM
what should I seal rocker bolt threads with? adrynalinjunkie Generation III Internal Engine 5 03-04-2011 09:30 AM
Head bolts. Thread sealer Dabeztz28 LT1-LT4 Modifications 1 07-05-2008 11:09 PM
Will ARP Thread sealer be ok to used on the Rocker arm bolts ? BadLtBlu99TA Generation IV Internal Engine 5 05-13-2008 11:26 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
    Get answers from community experts
What's your question?
Send
