Rebuild or run high milage 4.8? - Page 2 - LS1TECH
Thread Tools Search this Thread
Old 03-18-2017, 09:25 AM   #21
Do you rember the size/grit dingo ball you ran through it if i go that route.
transam197781 is offline   Reply With Quote
Old 03-18-2017, 09:37 AM   #22
KCS
Moderator
KCS's Avatar
Quote:
I'm going that route and picked up a set of Mahle rings from Summit for ~$40, PN 41859CP. It's a nice set with a Moly faced steel top ring, napier style second ring, and stainless oil rings. With the Moly faced rings, the Flex Hone rep I spoke with recommended the 320 grit, PN GB41832, which pretty much covers any bore size from the 4.8/5.3L to the LS7. Summit has them in stock for ~$56.
KCS is online now   Reply With Quote
Old 03-18-2017, 09:49 AM   #23
Sounds good good luck on your project.Thanks for the info.Do you take the crank out to hone or just the pistons?
Old 03-18-2017, 10:16 AM   #24
truckdoug's Avatar
take the crank out IMO
truckdoug is offline   Reply With Quote
Old 03-21-2017, 01:03 PM   #25
Forcefed86's Avatar
Quote:
Originally Posted by JoeNova View Post
People think I'm absolutely crazy, but everytime I buy a truck that I intend to pull the engine out of, I let it warm up to temp. Then I get a very small vacuum line, hook it to the intake, put a bolt under the throttle cam to make it idle at 4 grand.....
and I drop that vacuum line into a full gallon jug of windshield washer fluid.
Takes a few minutes to suck it dry. Using a bore scope, the carbon buildup is significantly reduced. Compression tests almost always yield better results, which is a sign that it helps with stuck rings.
I put used ATF through the engine the same way. It really cleans the gunk and frees up the rings. A gallon or so will smoke out the whole block.
Forcefed86 is online now   Reply With Quote
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
    Get answers from community experts
What's your question?
Send
