quote for machine work? - LS1TECH
Thread Tools Search this Thread
Old 03-20-2017, 04:37 AM   #1
Default quote for machine work?
I hate to bring up another one of these threads, but I'm curious if this is steep.
went to a shop near me and was quoted almost 1500 for a hot tanking, bore and hone, polish crank, balance rotating assembly, and install new bearings/assemble shortblock.
the thing that's giving me pause is they're only charging 300 for assembly, which leaves 1200 for the machine work. I have no problem paying for quality work, but I don't want to get ripped off.
thoughts?
alfablue is offline   Reply With Quote
Old 03-20-2017, 04:53 AM   #2
To me, it doesn't sound bad. In my neck of the woods, I received a couple quotes around that amount ($1200.00 to 1500.00). However, it did not include balancing the rotating assembly and assembling the shortblock.
2000GTP is offline   Reply With Quote
Old 03-20-2017, 05:40 AM   #3
99 Black Bird T/A's Avatar
Sounds with in reason if they do quality work.
Last two quotes I got for building a long block complete intake to oil pan, ready to install with me providing all parts and the very reputable shop providing all machine work and labor was $2500 to $3000. This including checking dis-assembley and re-assembly etc of the cylinder heads being provided.
99 Black Bird T/A is offline   Reply With Quote
Old 03-20-2017, 06:06 AM   #4
I paid 1200 for everything you mentioned minus assembly ( my favourite part ) from an extremely reputable shop
moekluse is offline   Reply With Quote
Old 03-20-2017, 07:23 AM   #5
Restricted User
The last quote I got for a .030" overbore on a 6.0 block, with hot-tank, finish hone, and new cam bearings was $150.
Taking a 5.3 out to a 5.7 with the same work done was $350.
JoeNova is offline   Reply With Quote
Old 03-20-2017, 08:30 AM   #6
Super Hulk Smash
JakeFusion's Avatar
Seems reasonable. Here is the shop I've used before and their pricing:
Bore + Hone Cylinder.......................................... ...............$25 per Cylinder
Bore + Hone single cylinder up to 1mm or 0.040”..................$50 per Cylinder
Clean Block............................................. ..........................$50.00
Replace Freeze & Galley Plugs............................................. $20.00
Replace Cam Bearings.......................................... ..............$40.00
Resurface Deck – “V” Block............................................. ....$160.00
Adjust Main Bore Diameter.......................................... ........$100.00
Clearance Block for Stroker Kit.............................................$1 50-$250
Race Prep Block............................................. ....................$140.00
Torque Plate Hone.............................................. ................$75 per Side additional
R & R Pistons on Rods.............................................. ...........$8 each
Resize Connecting Rods.............................................. .........$15 each
Balance Rotating Assembly.......................................... .........$275.00
Polish Crankshaft........................................ .........................$75.00
Darton Sleeve Install LS based............................................. .$2500 w/sleeves
JakeFusion is offline   Reply With Quote
Old 03-20-2017, 01:44 PM   #7
svslow's Avatar
Last year I paid $910 for hot tank, cam bearings, deck block, bore/hone with torque plate, balance and crank polish. In the Detroit area.
svslow is online now   Reply With Quote
Old 03-20-2017, 03:22 PM   #8
Sounds normal from my pricing around. I paid around $2000 for a shop to machine and assemble my stroker shortblock. That included balancing the reciprocating assembly, along with freshening up the 317 heads with new valves and BTR springs.
Matt330LS is offline   Reply With Quote
Old 03-21-2017, 12:45 AM   #9
Alright, thanks for the responses. The number at first seemed kind of high to me, but I suppose that goes with the saying "Quality work isn't cheap, and cheap work isn't quality".
Old 03-21-2017, 07:31 AM   #10
gagliano7's Avatar
I am not sure where you live but in ny near the city i was quoted between 1200-1500. One shop in jersey that was on horsepower tv LRB performance machine quoted me $3500 for the exact work you want done.
gagliano7 is offline   Reply With Quote
Old 03-21-2017, 12:34 PM   #11
Forcefed86's Avatar
My gripe with this is most of the the time you end up with a block that is less true than a high mileage OEM block. What are your power goals and plans for the engine? Depending on your goals, I've found it's better to try and reach your goals without involving the machine shop when possible. Pay a little more for a newer long block is great shape with lower miles and run a power adder of some sort.
Forcefed86 is offline   Reply With Quote
Old 03-21-2017, 06:10 PM   #12
were is that at im from ohio that's a great price
sbdgbody is offline   Reply With Quote
Old 03-21-2017, 11:12 PM   #13
Quote:
how does the block become less true?
I'm planning on h/c/i for now. Probably a supercharger at about 5 psi in the future.
Old 03-22-2017, 09:48 AM   #14
RollinSScamaro's Avatar
I just had my shortblock refreshed and had it assembled into a long block for $1800.. New cam, rod, main bearings, piston rings, arp rod bolts, polished crank, lightly honed the cylinders, and hot tanked it. They measured PTV and pushrod length for me, resized for ARP rod bolts, degreed my cam in properly (cam motion core, said it was spot on!), installed new rear main seal and oil pan gasket (I provided the rest of the gaskets). I feel like i got a hell of a deal, but still haven't started it yet lol. They don't do a ton of performance builds, but open to doing them as they come in. I will be starting it up saturday to find out how she does!
I forgot to mention, the best part is they agreed to a 90 day warranty on the shortblock! They really didn't want to, but i needed something for peace of mind.. i was expecting 15-30 days, but he said 90 and i ran with it lol.
RollinSScamaro is offline   Reply With Quote
Old 03-22-2017, 12:42 PM   #15
Restricted User
Quote:
Piqua. Probably a decent drive from you.
Related Topics
Thread Thread Starter Forum Replies Last Post
To build, or have built? alfablue Generation III Internal Engine 4 07-18-2015 03:56 PM
Corvette Headlight Assembly Passenger Side 1997-2004 C5 Flip Up Headlight LS1 Melly Parts Classifieds 4 02-08-2012 03:49 PM
Need recommendations on local machine shops in SoCal - Stock LS1 engine assembly andrewdruiz Western Members 11 05-31-2010 11:05 PM
Torque plate question BIG_MIKE2005 Generation III Internal Engine 16 04-20-2010 10:22 AM
LS1 383 long block assembly price Interlizer130 Generation III Internal Engine 9 09-05-2008 01:41 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
    Get answers from community experts
What's your question?
Send
