Engine Cranking Speed? - LS1TECH
Thread Tools Search this Thread
Old 03-20-2017, 11:21 AM   #1
Default Engine Cranking Speed?
I'm trying to diagnose an engine that won't run due to injectors not being pulsed by the PCM.
My question is-how fast should the engine turn with just the starter? My tuner is here with his lap top hooked up and his screen shows only 132RPM when cranking the engine over. He has HP Tuner software and it updates/refreshes very quickly so I believe what we are seeing on his screen is accurate.
I'm asking this question because I "think" my machine shop gave me the wrong crank back.. I took them a crank with a 24tooth reluctor ring, and I "think" they gave me a 58 tooth crank back in return, or otherwise if they had to remove the reluctor ring, they put the wrong one back on.
I would think that an engine would spin faster than that when cranking. If the machine shop put the wrong reluctor ring on the crank, or gave me the wrong crank back a 58tooth ring is going to show HALF the actual cranking speed... I think... Or maybe it would show double?
Kawabuggy is offline   Reply With Quote
Old 03-20-2017, 05:53 PM   #2
spy2520's Avatar
I'd guess around 140ish. Did you get a look at the reluctor wheel? Was it one piece?
spy2520 is offline   Reply With Quote
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
    Get answers from community experts
What's your question?
Send
