SRD 230/236 .620/.603 112+2, AI 226cc 243's, .040 cometics- RESULTS IN! Page 3!
111+2 think 11 degrees of overlap. I do on another thread here but I'll post them on this once I get home
Cool, so more overlap may end up balancing us out in the long run.. It should still be close enough to get an idea on the heads though. Hopefully it will give some good info for people looking at TMS heads in the future.. I was struggling to find results from them when i was searching.
Nice set up! Your car runs real well for being a smaller cam.. Appears to be 4 degrees overlap if i am looking at it right.
You happen to know your race weight? I think my only problem is i may be a touch heavy, but i think 11.50's should still be doable for me.
The following users liked this post:
99Ls1fever (10-01-2021)
^^^^ GREAT rule of thumb! ^^^^
Keeps the LSA the same too....
#32
I'm shooting for mid 11's on motor then down the road i'm thinking a 100-150 shot will finish it off for me.. i just want to make hellcats upset once in a while lol..
#33
Originally Posted by RollinSScamaro
Wow! Thats pretty light compared to me.. i'm guessing i am around 3600 range with me in it but not sure.. I think they are around 3500 stock if i remember right?
#37
I have power everything too and cruise with cloth and hardtop. I just do not have speakers in trunk area or the disc changer like some other cars. I can see a ttop leather Trans Am being much heavier. Just the rear spoiler on those are very heavy. My next plan is to replace my oem SS and wing(which were lighter than the Z28 pieces) with repos that are even lighter.
Maybe I can get a picture with it getting some air under the front tires....thank you for compliments
#40
NADA is showing mine as 3,517 lb.. I'm assuming thats with the spare tire and everything.. I will most likely run with front sway bar removed which saves around 25-30 lbs if i remember right (UMI sway bar) and the spare tire and jack has to be worth atleast 30 i'd think.. Racestar 15's with Skinnies up front, so i should be around 3580-3600lb range with me in it.. I still want to hit the scales to verify though, because i'ms ure my rough math is garabage lol.
