Robz style motor with Twin Turbos?
I just wanted to post a setup question like this. I am think of building a motor like Rob's that revvs to around 9k then adding twins to it. Anyone think it would work and run 8s even with a m6 trans am? Im just throwing it out there to see if people maybe agree with the idea or not lemme know your opinions!!
That was my other thought mainly as the 427 is my personal favorite motor. I want to be able to drive the vehicle on the weekends and I would like to have a full interior. These are long term plans for the car. I knew that robz car was streetable and just a little bit lighter than my 2000 ws6. Do you believe a full weight t/a would be able to accomplish that with the 427 setup as well? I know more displacement would make more power. I just had thought the reason Rob could run such a great time in his full weight, m6, vette was due to the high rpm. However I certainly don't know everything so I could be wrong. I do already have plans to get the t56 faceplated and built up along with a mwc 9" as well. However suspension wise im still searching around for. As I said these are long term plans and I am only 18 and don't quite have all the funds for such a big project all at once.
http://www.yellowbullet.com/forum/sh...d.php?t=558163
How much weight have you removed to be as light as Robz? Rob's car had a bunch of weight reduction:
Restricted User
Whats the obsession with wanting a huge engine that revs to 9 grand to run 8s?
You can run 8s on a stock displacement 5.3 with the cheapest forged pistons/rods you can find and 6500 RPM.
Hey just to add for clarity:
I went with high rpm because I wanted to stay small cubes(under 400) and n/a. I wanted to see how quick and fast we could go with those parameters.
Rpm is definitely hard on everything.
The ITB manifold was key in making that setup perfectly streetable.
The car when it had the 388 in was with minor weight removal for a C5z. The best times were 9.32 and 148mph. That setup was street/strip car.
If I put that motor in my c5 now setup as a racecar and much lighter it should run 8's n/a. I also build a n/a 396 that spun to 10K that may ~950fwhp on it's initial testing but sold that motor so never got to test it in my car.
So, I agree with most that if you want to run 8's with a 427 then do the turbos and lighten the car as much as you feel comfortable see how it runs. The rpm shouldn't be necessary and will add a lot more cost and maintenance to the build. You could always do a solid roller and spin it to ~7500 without much grief.
And keep in mind getting the power to the ground is a big part of this. You are going to need seat time in this car especially if its a stick. I'd probably do it in stages too so you can enjoy the car and learn how to drive it and what it's capable of.
BTW I have my car up for sale with the 346 cam only setup if anyone is interested.
Goodluck
Goodluck
By the time you have enough to start this sort of build the current technology will have already passed the parts and setups you're thinking about now...... unless you have lots of high performance resources and about 15 grand tucked away under your pillow. For all I know you can start this build next week, we all start somewhere and everyone has different resources available.
