when cam was installed i purged my AC..now what?
I got a can of 134, now what do i have to do? i dont need to flush it, just add so i can use my AC in this 100degree heat
If you live in a high humidity area like we do in Okla, you can charge it until you get condensation on the accumulator and be pretty close. Freon is less than $3/can around here so if it were me, I'd release it all and pull the vacuum and add the 2 full 12oz cans. It helps to have the vac pump and manifold gauges like I do though. Your only other alternative is to take it to a shop where they have a recovery machine and have them recover what is left and then inject the proper amount.
I don't mean to hijack, but, I've been wondering about this. All the cam install writeups I've seen say you need to purge the AC. Why do you have to purge it? Is it just to give you more room to work? Or is it actually required?
Thanks!
Thanks!
Thanks!
Thanks!
so you tapped the schreader valve and let some gas out? I wouldnt' top it off. I'd go to an independant shop and get a evac and recharge, probley needs it anyway. Atleast then its going to have proper charge, oil and be evacuated properly for probley $45-60 bucks.
