comp cam
Old 06-29-2004, 08:05 PM
v8
17,16,15,14,13,12,11 Drvr
v8's Avatar
Default comp cam
ok i've never posted here but what would this cam do in a truck that weights in at 4500lbs getting a tt3000 stall and 4.10 gears and posi "Comp Cam 228/232 .571/.575 114+4" thanks in advance kevin
Old 07-04-2004, 02:50 AM
lsx24's Avatar
Well, that's quite a smart setup with that cam it should start to come on at just about 3k and really start to cook ~ 4k. You may be just about right with a 3k stall plus or minus that truck's gonna haul!
Old 07-04-2004, 07:04 PM
v8
v8's Avatar
thanks, alot of people think its to big so we will see when the time comes lol later, kevin
Old 07-04-2004, 07:47 PM
BigTex's Avatar
Is this in a 5.3? If so, I think its too big. Be prepared to spin to 7000.
Old 07-05-2004, 02:00 PM
lsx24's Avatar
Why do you say that? All the dyno graphs I have seen with similar cams peak just over 6k or 6500 for a few depending on which one you install.
Old 07-05-2004, 02:48 PM
someday's Avatar
dyno graphs from 5.7's, i'm sure, in a smaller 5.3, it will peak higher, and in a truck that weighs 1000lbs more, it will be a dog off the line...
Old 07-05-2004, 03:03 PM
lsx24's Avatar
Ok, so I assume with the smaller displacement it would have a higher peak...but do you still believe it won't get moving as fast with a 3000 stall installed? Isn't that were this cam would start to pick up speed?
Old 07-05-2004, 03:11 PM
LSxGuy widda 9sec Mustang
-Joseph-'s Avatar
The biggest camshaft I would consider running in the 5.3l would be something like a 225/225 camshaft...
Old 07-05-2004, 04:35 PM
BigTex's Avatar
A 3000 stall really isn't enough to make up the difference. It may pull like a demon in the upper rpms, but the low end will stink and it will be slower than stock. Just as someday said, that extra weight of a truck and the smaller displacement will have a big effect.
Old 07-05-2004, 09:05 PM
Zapata's Avatar
that cam is WAYYYY to big for your truck....my friend has a big comp grind in his truck and it runs like a scalded ape from 3500 on, but from a dead stop it wont even hardly spin the tires.
