what head gasket do i use for 5.3 heads
LSxGuy widda 9sec Mustang
Use the gaskets specified for your engine displacement, use OEM 5.7 for 5.7 blocks, use 5.3 gaskets on a 5.3 blocks. If you use a gasket that has a smaller bore than your piston, you will have engine noise as the piston will make contact with the new gasket.
