Main torque specs with studs?
Old 07-03-2004, 07:54 PM
SStroked 410's Avatar
Question Main torque specs with studs?
I am finally getting this motor put together and was wondering what the torque specs would be with main studs? I bought this motor used and I dont know what brand they are, most likely ARP.
thanks
Old 07-03-2004, 11:10 PM
I can shift faster than you.
Jason99T/A's Avatar
60 lb-ft on the inner bolts and 50 lb-ft on the outers, with ARP molylube if they are ARP mainstuds. The side bolts get 18 lb-ft.
Old 07-04-2004, 12:06 PM
Old 07-04-2004, 07:47 PM
ktmrider's Avatar
Yep, right on the money. Use the std torque pattern of inners from center to ends, outers from center to ends, and sides from center to ends. Good luck.
