warped ls6 driver head
The drivers side head is warped. Don't know what to do they are stock 243 casting heads i all ready have a tsp 231/237 cam in . The head will have to get milled the head is warped .4 thousands so i guess i will have to go to 5 on both heads so they are usable.
any ideas ?????
thanks
any ideas ?????
thanks
You can get a set of Cometic gaskets in the correct thickness to make up the difference. Or I would say have the P/V clearance checked it may be OK with stock valves.
Nate
Nate
Thicker head gaskets don't give you exactly the same result as a stock head surface height. While you end up with the same piston-valve clearance, the thick gasket leaves more space in the quench area, lowering your compression slightly and leaving you with more detonation potential. Don't take my word for it, read Vizard.
The heads are at the machine shop today i will get them back tonight. So do you think it would be better to go with a feel pro .40 or stock .53 crush. To avoin detonation . I am also{" ARP Studing " the block in hopes of getting a better clamping force on the heads.
Just a new :
Heads had to be shaved .010 so i guess i am at 11.5:1 now i got MLS Ls6 head gaskets is there any thing i should know about a high compression like that
chris
chris
Originally Posted by 00sscam
Just a new :
chris
chris
Thanks for the info i did not know that about compression i went with the mls becaus i did not know if the .40 with the felpro would cause P/V clearance.. Thanks again
chris
chris
