91 octane highest compression ratio?
Old 07-10-2004, 01:13 AM
cz2898's Avatar
Default 91 octane highest compression ratio?
What is the highest compression ratio that you can safely run on 91 octane gas because that is the highest i can get my hands on out here in colorado?
Old 07-10-2004, 02:56 AM
strokedls1's Avatar
I run 11.2 with 28 degrees of timing with cali 91. I would stick around 11.5 or lower, and go with a thinner head gasket to reduce quench. You will need to tune it to cancel any knock. Detonation killed my last 11.8-1 346ci.
Old 07-10-2004, 06:10 PM
Linear Velocity's Avatar
Yeah I would say 11.5:1 is the most you could get away with on 91 with max timing, that's what my heads/cam setup was and it ran fine on CA 91 octane. A lower lsa cam and colder plugs will help too will help bleed off some compression too. Good luck.
Old 07-11-2004, 12:33 AM
SSpeedracer's Avatar
Colorado is like 1000 miles above sea level right
Your mass flow efficiency will be less than Cali so I would guess that you could get away with more compression than an equivalent car in CA. Isnt this one of the reasons you have 91 in CO?
I say go with a supercharger! That would be huge where you live.
Old 07-11-2004, 10:54 AM
Blue Hawk's Avatar
Hmm... blower will do nothing for his car at that altitude, I would invest in solar panels instead.
Eric D.
99 Firehawk M6
Old 07-12-2004, 12:20 PM
cz2898's Avatar
I was thinking blower cuz thats the only way to do it up here but not enough $$$
Old 07-12-2004, 12:44 PM
God of Thunder's Avatar
you would need a high psi one too, or else it would only make it run like you were at 500 miles above sea level
Quick Reply: 91 octane highest compression ratio?
