AFR heads are NICE!
Old 07-11-2004, 12:31 AM
M6HuggerSS's Avatar
Arrow AFR heads are NICE!
i was in GEN3 performance the last 2 days doing a H/C swap and SCOTT had a new set of AFR 205cc heads and they are really nice! the CNC work looks
great, chambers 66cc but look differentn than a 5.7 or LS6 head!
to bad there $2000+
Old 07-11-2004, 12:59 AM
Ben R's Avatar
I got to check out bare 205cc casting the other day when I was at GTP. The potential for those heads is almost limitless. 500RWHP heads/cam cars here we come.
Old 07-11-2004, 10:33 AM
O2bqwik's Avatar
yep and the 225cc heads should help make 600rwhp strokers a common place. im patiently waitin on some of these new parts to come out.
Old 07-11-2004, 11:06 AM
JZ'sTA's Avatar
I disagree myself, but we will have to wait and see.
What holds us back more than the heads is the intake setup's we have on LSx motor's.
The heads will generate better flow numbers than ever before and will make more power but 600 a common number isn't very likely.
Old 07-11-2004, 11:26 AM
O2bqwik's Avatar
i dunno i think these heads w/ on of the new intakes like the lsx w/ 90mm or ls2 and a nice sized cam not a solid roller. i think its possible with the right combination of parts.
Old 07-11-2004, 11:35 AM
PREDATOR-Z's Avatar
All this is speculation.
I felt the same way about 205's untill I saw the results of a 1 to 1 swap VS LS6 heads on a ZO6 at LAPD. That evaporated any doubt I had about the AFR's potential.
Let us wait for the test results.
Old 07-11-2004, 11:55 AM
Ben R's Avatar
It doesn't really matter what they flow out of the box. As long as they make power once somebody with an EXTENSIVE knowledge of cylinder heads and air-flow characteristics gets to work on these heads, the potential is huge.
Old 07-11-2004, 01:12 PM
Iv_z28's Avatar
Um... so in your opinion AFR doesn't have extensive knowledge of heads and air-flow? umm... Ok... yeah, right
Old 07-11-2004, 01:46 PM
Ben R's Avatar
That's not what I'm saying. What I'm saying is that we'll have to wait until head-porters get their hands on these bare castings before the true potential is discovered.
Old 07-11-2004, 07:54 PM
BTL FED's Avatar
CFM doesnt mean that the heads will make huge amounts of power, What makes the AFR's so good is that you get good flow numbers 300cfm out of a 205cc runner which means you get great velocity and cylinder filling, which means bada$$ hp and torque, plus it wont be another 430rwhp car that runs 12.50's
Old 07-11-2004, 07:55 PM
WS-Sick's Avatar
I just want to see some numbers already....call me impatient but I want to know what heads I'll end up going with.
Old 07-11-2004, 08:02 PM
deviate42's Avatar
my guess is head porters will just "touch them up", from what i am hearing, it may be best to leave them the way they are
Old 07-11-2004, 08:27 PM
HumpinSS's Avatar
I dont see why people would want anyone touching something that is allready perfect
Old 07-11-2004, 09:22 PM
ArcticFormula's Avatar
Saving cash right now for the 205, going to get a mild cam to go with em, 220-220 116LSA or around there. Hoping for 370-380+ RWHP through stock manifolds and cats in my stock A4. Nice little sleeper vehicle, hope people (ignorant) keep ******* these heads so I get a cheaper price come December.
Regards,
Old 07-12-2004, 01:50 AM
Iv_z28's Avatar
Regards,
That's a great plan
Old 07-12-2004, 06:39 AM
Viper's Avatar
"All this is speculation.
Let us wait for the test results."
What were the results you saw? I missed that post. Thanks PredatorZ.
Old 07-12-2004, 09:14 AM
PREDATOR-Z's Avatar
Before swap Z06 385rwhp w/tune
After out of box AFR 205 66cc 409rwhp 391tq w/tune
https://ls1tech.com/forums/showthread.php?t=185758
Then I got a tip on TSP special offer $2189.00 with dual PP "gold" springs, so I ordered a set getting them flat milled to 62cc (11:1 CR with Cometic gasket)
Old 07-12-2004, 09:39 AM
Viper's Avatar
One other thing.
I recall a while back the discussion on better locks being designed by someone and then sold with the dual gold Patriots springs. Someone had tried a timing light on stock locks and had discovered serious issues. Does anyone know if these have the updated locks?
Old 07-12-2004, 10:05 AM
6600 rpm clutch dump of death Administrator
J-Rod's Avatar
CStraub was working on a Super 7 lock...
Old 07-12-2004, 10:14 AM
Viper's Avatar
So he never completed it? From what I recall this was supposed to help alleviate changing springs so often on these cars.
