What causes a lifter to collapse?
Old 07-11-2004, 11:09 AM
BDD
BDD's Avatar
Default What causes a lifter to collapse?
Just like the title says.
Old 07-11-2004, 12:08 PM
Grimes's Avatar
Well, if the valvetrain is set up improperly, and there is binding, that will collapse it. Also, a really agressive cam lobe can do it too...
Old 07-11-2004, 10:00 PM
soundengineer's Avatar
Possible things to colapse a lifter:
worn out lifter
too much preload
too short a spring/too much lift for the spring
huge lift and fast ramp rates
too heavy of a spring(seated pressures)
something getting into the oil(metal shavings/dirt)
Old 07-12-2004, 04:37 PM
BDD
BDD's Avatar
Would a texas speed camshaft 228R cause the lifters to fail? It has 228/228 and .588"/.588" lift and 112lsa. Also what would be the best lifter to replace the stock lifters, but still use stock rocker arms?
Thanks
Old 07-12-2004, 04:49 PM
94form2000z's Avatar
Man I replaced my stock lifters with a new set of stock lifters when I did my cam swap. I have about 12k on them now with no valve float. I am running the same cam.
