best heads to go with the g5x2 cam?
Old 07-11-2004, 11:23 PM
mike c.'s Avatar
Default best heads to go with the g5x2 cam?
what heads will make the most power and be the verry best for my x2 cam? thanks, mike c.
Old 07-12-2004, 12:45 PM
MyLS1Hauls's Avatar
Mike, dont you have MTI S2 heads? You can't get much, if any better than that IMO.
Old 07-12-2004, 02:38 PM
mike c.'s Avatar
man,you have no clue to the problems i am having.
Old 07-13-2004, 03:00 PM
mike c.'s Avatar
all these members and nobody?????
Old 07-13-2004, 03:45 PM
mike c.'s Avatar
looks like i need more reaserch.
Old 07-13-2004, 08:03 PM
mattz06's Avatar
Patriot!
Old 07-13-2004, 08:13 PM
mike c.'s Avatar
i'm looking at patriot and AFR even GTP
Old 07-13-2004, 08:17 PM
algws6's Avatar
i had some TEA stage 2 5.3 heads and put down 440 rwhp & 408 ftlbs through a 12 bolt with 4:30s and 18x10 wheels with some 315s. i ran an 11.7 @ 117 with a DA of around 6000'.
Old 07-14-2004, 02:07 PM
Stone0fFire's Avatar
i thought LG was getting the highest numbers
from Absolute Speed heads?
Old 07-14-2004, 02:13 PM
2001CamaroGuy's Avatar
my feeling
#1 = Absolute Speed
close 2nd = MTI
Old 07-14-2004, 04:24 PM
mike c.'s Avatar
patriot heads are out. absolute speed....i'll take alook. 2000CAMAROGUY- why do you feel they are better then MTI.
Old 07-14-2004, 04:45 PM
MONGOOSEWS7's Avatar
try afr's.
Old 07-14-2004, 04:51 PM
From the flow numbers I have seen, they seem to be doing a little better (though MTI makes really good big CI heads.....). I have nothing bad to say about MTI (they are a good company also). Just working off of good feedback from absolute's customers.
Old 07-14-2004, 05:57 PM
!LS1 11 Second Club
SouthFL.02.SS's Avatar
Option #1: AFR 225 that will be coming in a couple months.
Option #2: Stage 2.5 True LS6 Castings by either TEA or Absolute.
Option #3: 6.0 liter heads with welded chambers by AP Engineering.
Old 07-14-2004, 09:31 PM
mike c.'s Avatar
southflss-how do you know the afr heads are good if they are not even out yet.
Old 07-14-2004, 09:44 PM
STLWS6's Avatar
I would get Bare AFR's and have them ported by someone who knows what they are doing. Then get a cam to match the rest of your combo.
Old 07-14-2004, 10:12 PM
Cstraub's Avatar
Cam is the second to the last part that is determined. The last being pushrod length. You need to sell the cam, select heads then make a combo.
Chris
Old 07-15-2004, 08:08 AM
!LS1 11 Second Club
Though no real #'s are out yet, the 205's seem to be the real deal.
225's would be good for the G5X2.
Old 07-15-2004, 08:11 AM
CHRISPY's Avatar
Chris
EXACTLY what I was going to say!! You are going about this BACKWARDS!
Old 07-15-2004, 06:04 PM
mike c.'s Avatar
well,i already have the cam i want,the g5x2. now i'm looking to upgrade the heads to match. and i have NO clue what heads to get. MTI,AFR,ABS-SPEED,TEA. so many heads,i cant take it.
