Oil pump internals
Old 07-12-2004, 01:17 PM
Boostaholic's Avatar
Default Oil pump internals
Ok, so I disassembled the oil pump that I suspected to be defective last night, and the rotating assembly looks to be fine but there is a little valve looking thing with a spring under it (Spring is loaded through the hex nut on the outside casing) and the valve would not move at all.
Am I correct to assume that the valve that appears to be stuck should actually move?
Old 07-12-2004, 02:24 PM
SNW Vette's Avatar
Default Oil Pump Pressure Relieve Valve
Hi,
The steel piston is the pressure regulator valve. It is closed by the spring pressure until a certain value then it unseats to bypass oil to limit the maximum oil pressure. It needs to move freely in the bore.
Good luck,
Steve
Old 07-12-2004, 03:38 PM
Originally Posted by SNW Vette
Hi,
Good luck,
Steve
Thanks for the info! This is definantly the problem then! The pressure regulator valve will not move.
I'll be putting a new oil pump in tomorrow and hoping for something about 0 PSI
