Need cam Suggestion Please....
...with cheese.
This isn't the right type of topic to search for, seeing as how everybodies is different, or I wouldn't waste your time. My current mods are, Long Tube Headers, High flow lid, no cats... free flow exhaust, fast 78mm, underdrive pulley, injectors... tune all the free mods, etc... no internal mods, or heads or anything, I would like to attempt heads in the future but If I do decide to do that I'll just rework everything. So don't factor heads in. I would like to play with a small shot of giggle gas, I know my internals are stock, so I'm not planning on more than a 75shot. Emitions obviously arent a factor here in southern alabama, and I don't mind a rough idle either. Thanks a bunch guys!
You didn't say if you had an A4 (with a high stall or stock) or an M6. You didn't post gear ratios. What do you want to do with the car (drag/street/road/daily).
With that small off a shot, you don't need a nitrous cam. ANYTHING is going to need new valve springs. With stock head you want more intake duration than exhaust to help make up for the low flow (the exhaust will flow plenty).
