How does this cam compare to the TR224 114LSA
1 Post
TR 224/224 .561/.561 114 LSA
Comp Cams 222/224 .563/.563 114LSA
How much less power will this cam make compared to the TR224? Also, wouldn't this be a decent cam for sprayin a 100-150 shot?
Thanks
Thanks
6600 rpm clutch dump of death Administrator
Originally Posted by Z28Venom
ttt..
I guess there isn't much difference.
If you cam doctored the two cams you might not be able to see much difference, as 1-2 degrees is within many grinder's variance.
But, the .050 don't tell the whole story, so you'd have to know the .006, .050, and .200 to make an educated guess athe two cams, or have it cam doctored.
I would go with the TSP 225/225 .589/.589 112 www.texas-speed.com
https://ls1tech.com/forums/dynamometer-results-comparisons/162312-40rwhp-gains-new-225-camshaft.html
https://ls1tech.com/forums/showthrea...&highlight=225
