Stage II 5.3 heads with comp 222/224 on 112
5.3 stage II heads
Comp 222/224 .566/.568 on 112 LSA
Would this setup be good for a full bolt on A4 with 3.42's and a 3000 stall?
I want something very mild in manor but has *****. It has to idle well. I've already got the heads so I guess the real question is would this cam be a good bet.
If you want a stock idle, the the Stealth would be a good cam, like Ragtop says. But if you really like the specs of the Comp, then, yeah, it would idle a little smoother on a 114. I would imagine it would be close to a stock idle. You should be fine. Looks like a good sleeper combo with those heads, and matches well to your smallish converter.
