FMS F13 or G5X2
Old 07-18-2004, 10:24 PM
LS1 BU's Avatar
Default FMS F13 or G5X2
I currently have a F13 cam 230/232 .59x/.59x 113 lobe 4 degress advanced. I was thinking of a G5X2 on a 114 lobe sep. Specs would be 232/240 .59x/.60x 114 lobe sep 4 degress advanced. These would be combinded on a stock shortblock with stage two TEA 5.3 liter heads milled .010. This combo will be seeing a 200 shot my NX wet kit.
I think the G5X2 would be better for spray. Would I have enough piston to valve clearence? I thought the Chicago Z06 was running a G5X2 on a 114 lobe sep with GTP stage two heads milled .015. What do you guys think?
Old 07-19-2004, 08:30 AM
1fastWS6's Avatar
You'd have to measure to be 100% sure on the P-V clearance. It'll probably be tight, but it might be fine.
You can always do a "valve drop" test and see how close things are before buying the cam. That'll get you in the ball park. Call LG and see what the recommended valve drop # is for that cam. I think it's .080" on the intake side.
Old 07-19-2004, 08:58 AM
LS1 BU's Avatar
I was thinking it would be close but would clear. I think the 114 lobe sep would give me some clearance over the 112. I think this cam would work better than the f13 on spray. Any other comments.
Old 07-19-2004, 11:45 AM
LS1 BU's Avatar
No one has an opinion??
